Question about Whirlpool Duet GHW9150P Front Load Washer
Machine is blinking f25 in time window - Whirlpool Duet GHW9150P Front Load Washer
  • 46 Answers
There should be a tec sheet in or on your washer find this it will tell you what the problem is
Posted on Jun 26, 2009
  • 15,935 Answers
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 minutes.
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
My whirlpool duet washer has f25 on it. How to fix it?
F25 is a communication error between the motor control unit and the main board, it's not sensing the proper RPM.
Dec 10, 2016 | Whirlpool Washing Machines
F25 code on 3000 series maytag washer
Google search brought up:-
F25
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
A serious and difficult fault to repair. Call a technician.
Nov 13, 2016 | Maytag Washing Machines
Whirlpool duet sport error f25
F25 is a communication error between the mcu(motor control
Nov 05, 2016 | Whirlpool Washing Machines
Error code f 25 is blinking and the washer will not do any thing'
The F25 error code is indicating that the control is unable to detect the motor speed. Causes of the code could be the motor, loose wire connection, failed motor control board or a failed machine control board.
Jan 18, 2011 | Kenmore HE2 Plus Front Load Washer
Computer will not power up. Orange power light blinks 5 times, the 3 times and the pattern continues. What do you think the problem is?
Ok you are right they are codes. here is a page for you.The only 1 I could find in almost an hour.http://www.hardwareanalysis.com/content/topic/51345/
There are links but I could not connect to them. Why ? unknown.
Oct 11, 2010 | Toshiba Qosmio F25-AV205 Notebook
My he5t is giving me f25 code. i have pressed stop and tried to drain but i get f25 again. do i need a new belt?
Here is the info on "F25":
f25_code.jpg?t=1177554999
When you open the top of the washer, look at the black rubber hose leading up to the pressure switch. If the hose is kinked, it will fool the pressure switch into thinking the washer is either full of water or it did not see a water level change after the water valves have been on for a period of time. These failures generate the F20 / F25 codes.
To Clear the F25 Fault. Disconnect & Connect the "Water Level Presure" switch plug, a couple of times, Give it a couple of light "Taps" Reconnect again, and see if that works, it should.
Feb 16, 2010 | Kenmore Elite HE5t Washer
How to fix a code f25 kenmore elite he5 washer
F25 dispay comes on the washer stops. What is this and what can I do? Thanks, Ray
Nov 09, 2009 | Kenmore Washing Machines
Kenmore Elite F25?>
F25 = DRIVE MOTOR TACHOMETER ERROR
mostly likely need to replace speed control board
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations
Oct 19, 2008 | Kenmore Elite 45986 Front Load Washer
F25 code for brand new washer
F25 is a keys stuck error code which must be covered under warranty..The only option is to replace the keypad..I suggest that you pester those customer support fellows so that you can get it fixed as it is a pretty complicated process to do it yourself..
Oct 23, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
125 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
