Question about Dell Inspiron 1545 Notebook
Not loading. Basically, the laptop stops loading just before the welcome screen [running on vista]. It gets stuck with a black screen and a cursor which I can move. Sometimes when it's loading it does a disc check.. It will load in safe mode [without network] but after then I don't know what to do? Can someone help me please? Thankyou :)
  • 1 more comment
  • bulletsaresc Jun 26, 2009
    Well it's not my laptop but he says nothings been changed..
    Ok. Now it won't even start in safemode, it just goes on the blue screen.. i'm gonna keep trying to get it to work but if it doesn't I shop just take it to a shop?
  • seth veloso May 11, 2010
    Have you made any changes? New software, or hardware or any updates? Let me know then we can figure this out
  • 334 Answers
OK, first thing to try is download malwarebytes, install it in safe mode then run a scan in safe mode. This will make sure its clean and you don't have anything messing with your winlogon.exe. use the following link then let me know
seth
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-8022_4-10804572&ontId=8022_4&spi=4a91a6242a5736e54ab1eb5a49b45a44&lop=link&ltype=dl_dlnow&pid=11039785&mfgId=6290020&merId=6290020&pguid=NaDy6QoPjAMAAEiQ280AAAAx&destUrl=http%3A%2F%2Fdownload.cnet.com%2F3001-8022_4-10804572.html%3Fspi%3D4a91a6242a5736e54ab1eb5a49b45a44%26part%3Ddl-10804572
Posted on Jun 26, 2009
  • seth veloso Jun 26, 2009
    sounds like a hardware problem, try using only onr RAM chip, switching spots, this will tell you if you have a bad chip or bad slot. Also, try without dvd rom, without hard drive, without wireless card. This will tell you which device could be the problem. try to get into the bios to see if it is working once the hard drive is out. you can also do a hard drive diagnostic in bios
My Acer Extensa 5230 wil not load windows.. can get the DOS screen but just get a black screen with a white cursor when it tries to load windows. it is running windows vista
go into bios by hittin F10 when it starts up go to diag and run a test on hard drive to see if its bad. tell me if it passes bc if its good there are a couple of other things it could be.
Jan 27, 2010 | Acer Extensa EX4420-5239 Notebook
Startup screen goes black except for the cursor
Get a new OS Installer, I suggest you take Windows 7
Oct 18, 2009 | Dell Inspiron 6000 Notebook
When I power up the screen flickers for a milisecond and returns to black. The fan runs. The hard drive gives a quick 2 second green followed by two pulses of amber for several minutes and then just quits
It sounds as if you have one of two possible problems, either the light tube in your screen is burnt out or windows is unable to load the video driver. When you see the HD green, it means the drive has started, the amber indicated it is working to load the operating system and then it stops - basically indicating it has found something it cannot load or is missing some files or is possibly busy. If your screen shows either the logo or the boot up screen (black with white letters usually), then the screen is working and it is a windows problem. Occasionally on updates or hardware changes it will take windows 5 minutes, up to a half hour at most to load - if you have a flashing cursor in the upper left corner of the screen, try just waiting to see if it will eventually load.
Oct 02, 2009 | HP Compaq 6715b Notebook
Vista boots just Black screen with cursor even in safe mode
Yes, this is a known issue with Vista. You need to back-up your data, format your hard drive and re-install Vista from the beginning.
There is really no use trying to repair it: it is damaged.
After you re-install Vista, do not forget to install service packs from microsoft.com.
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
Toshiba Satellite A300 blank Screen with cursor Vista won't load
Compatability Issue with Vista.
Likely to be a Hard Drive Issue.
Dec 09, 2008 | Acer Aspire 3690-2196 Notebook
Locked cursor on Toshiba Satellite using Windows Vista
you need to press f8 on boot when it is loading, to enter safe mode (before the Windows flash screen)
then when in "Safe mode" you can  should be able to gain access,
reboot from this mode and see if it loads normally,  if not then you have a configuration issue.
go back into safe mode, (login) and go to start>Run,  run a program called MSconfig,  this will allow you to look at your startup items,  and allow you to disable/enable them individually,
from this point you can diagnose which programs are causing your issues.
I hope this helps
Oct 11, 2007 | Toshiba Satellite A135-S2276 Notebook
Dell Inspiron 1545 Notebook Logo
267 people viewed this question
Alun Cox
