Question about Vizio P2 42 in. HD-Ready Plasma Television
HD cables not working on ps3
I just got av hd cables with the gold tips at the end
so i unpluged the older ones that came with the ps3 an plug in the ones that would make my ps3 into hd its a rca hdtv so having a hdtv not the problem then next it asked me what my tv resolution was i put in all of them mix and matches but none worked
  • 34 Answers
You can get hd picture only with hdmi cable
Posted on Jun 26, 2009
Doesnt show up on the television. It does turn on. turned playstation on and off, tried different connections, still nothing
It is likely that the problem is your AV cable. This cable has one plug that connects to your Playstation 3 and a red plug, a white plug, and a yellow plug that connects to your television. Follow these steps to get your PS3 up and running again
  1. Unplug your AV cable from your PS3 and T.V.
  2. Plug in your AV cable to your PS3 and T.V.
When plugging your AV cable back into the T.V. make sure that the red plug is in the red socket, the yellow plug is in the yellow socket and the white plug is in the white socket.
If problems persist try using a different AV cable.
Jun 13, 2011 | Sony Playstation 3 (PS3) Console
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    Mitsubishi WD-62627 Projection DLP TV help with PS3
    To localize issue better try plugging your xbox into input for your ps3 and see what happens. You may have a bad input. Happens.
    Aug 28, 2017 | Mitsubishi WD-52725 52". Rear Projection...
    We bought a hardly used ps3 for our son for x-mas. We have tried hooking it up but can't get it too play. The tv is not an HD tv, the older style tv, also have a cable box attached to the tv. Plugged the...
    or the previous owner of the ps3 had the settings on the system on HD settings and now the Non-HD TV cannot recognize the signal. In order to change the settings you have to find someone with an HD TV and switch the output settings from HD to AVI
    Dec 30, 2009 | Sony Playstation 3 (PS3) Console
    No picture or sound
    Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
    Aug 05, 2009 | Sony Playstation 3 (PS3) Console
    My ps3 has no picture or sound...
    if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
    Jan 22, 2009 | Sony Playstation 3 (PS3) Console
    Hd tv as no hdmi plug
    There are PS3-components cables available out there (the Red/Green/Blue one) you can use to connect your PS3 to your TV and still get HDTV on your TV system. You should be able to get it where you bought your Playstation. Got one for 39.99$ CAN
    Cheers
    Dec 22, 2008 | Sony Playstation 3 (PS3) Console
    PS3 will play on AV but will not in HDMI
    1. Connect via AV and turn on the system.
    2. Go to Setting and then Display setting
    3. Select the connector type on your TV.
    4. After you selected connector your TV screen may go staid black. Try to hook your HD cable while the system is still on. (This step should be done in 30 sec. If not, will go back to previous screen)
    5. Your TV Screen should be on via HD cable
    Dec 09, 2008 | Sony Playstation 3 (PS3) Console
    Vizio P2 42 in. HD-Ready Plasma Television Logo
    96 people viewed this question
    Top Vizio Televison & Video Experts
    pzarnold
    Level 1 Expert
    Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
