Question about Hussmann Freezer 12 Facing Straight Glass Front Ice Cream Dipping Cabinet - With Rear Storage Doors
How to tell if you have a bad suction valve for ac compressor?
  • 334 Answers
Hey there. First question I have is if you have a heat pump or straight ac. Straight ac is easy to diagnose. Your suction pressure will be high, your head pressure will be lower, not sure how clean your condenser coils are so its hard to say how high. Your amp draw on your compressor will be lower than normal. Also, when looking at the suction pressures, you have to keep in mind what temp the air hitting the evap coil is. If it is warm, that will make your suction pressure go up. Another way to check the vavles is to hold the suction line at the compressor when you shut it off. If the temp goes up the second you shut it off, this tells you the hot gas is leaking through your suction valves. You can also try to pump the system down, then shut it off and see how fast the pressure builds back up, this will give you and idea how fast it is leaking through. Let me know if you need any thing else, I'll be here.
seth
Posted on Jun 26, 2009
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
Is it possible for a delfield freezer 6151 XL-S to trip a breaker every 2-3 hours if the TXV valve was faulty letting liquid get to compressor. This unit has had controller and relay start assembly...
I would look to see if it is tripping during the defrost cycle. One of the heater elements my be faulty. Never heard of a bad TXV causing a breaker tripping, but I guess it's possible. I would adjust the superheat so that it is about 6 to 8 degrees just prior to unit reaching temp and shutting off. I'd start there.
Apr 01, 2011 | Delfield Freezer 6151XLSR Stainless steel
I replaced compressor for a hussman refrig and its hums loud
God day,
Some thoughts.
1. Are the evap fan motors running, and at full speed. That would give you abnormally low suction pressure.
2. Cap tube sized too small. or partial restriction in the dryer cap tube/dryer when brazing in the lines.
3. Low ambient. What's the temp the machine is running in.
4. Over sized compressor.
5. Moisture. God, 134A is touchy on that one.
6. Was original cap tube soldered to the suction line to create a heat exchanger. Needed on many apps. Definately would cause flash back on start up.
7. Superheat a little low, should be 12 to 15 degrees.
Jan 31, 2010 | Hussmann Freezer Gelato Pan Rack (For 12...
I want to use one condener unit to cool a freezer and a cooler at two different temperatures, how do I do that? with a head master?
You need to split the delivery and return tubing, then install a solenoid in each delivery tube. The solenoid valve will be controlled or powered by a thermostat in each compartment. You then install a low pressure switch on the suction or return side near the compressor. This will switch the compressor off when both solenoid valves are closed. Hope this makes sense.
Nov 05, 2009 | Freezers
My freezer is not freezing properly
It is overcharged with refrigerant. The "Hissing" noise is the internal relief valve going off that is located inside the compressor shell itself. This is a safety device and can possibly effect the compressor performance.
If you need more info, let me know and I'll try to break it down some more.
Good luck and hope this helps.
Apr 08, 2009 | Freezers
Hoshizaki km-1300skf 3 beep error code
The 3 beeps indicates that the freeze cycle is longer than 60 minutes. with the suction pressure at 20, it sounds like low on charge (freon). I believe this is an R 404-A unit. Other things to look for are: Stuck float switch (in the up position), Water valve leaking, hot gas valve leaking, txv not feeding properly, weak compressor. Look at high side pressure too. It should not go below 210 psi during the freeze cycle. Low pressure should be in the middle to upper 40's psi.
Let me know if you need more.
Jan 02, 2009 | Freezers
Compressor will not start
Take and close down the suction valve on the compressor and then try to start the unit after you recover some of the refrigerant out of the compressor the reason that it is acting like that is probebly because the compressor is full of refrigerant and slugging the valves. also verify the you have all the lesgs of power going to the unit. let me know how this turned out.
Dec 24, 2008 | Master Bilt 95 cu. ft. Commercial Freezer...
DANBY DCF 520W
if the compressor runs but your not getting cold, 90 percent of the time one of two things has happened. either the compressor valves have gotten weak over time and the process of moving and warming up allowed it to defrost and now it has to pull down from a hot box to freezing and just can't because the valves prevent 100 percent efficiency and it struggles to achieve temperature.however i think most likely is that the delicate , brittle , and highly suceptible steel tubing in the outer skin of the box has ruptured and the box has lost its refrigerant charge. these are sealed systems usually with no place to apply a gage to verify if charge is low or valves are bad. if by some chance it has access ports where you can apply a suction gage, a pressure of 20 to 40 punds is close for a hot box and pressures of 60 and above may indicate weak valves. if you are running less than 10 pounds or in a vacuum then the charge is gone, leaked out . unfortunately a new compressor is usually to big an investment in an old box. new is cheaper! and if the tubing in the case has ruptured, then its inaccessible and box is condemned also. sorry to be the bearer of bad tidings but many times a new box is a blessing and saves you from sinking a ton of money in an old one. imagine your frustration if the compressor went bad cause it was low on freon and you paid for a new compressor only to have it die in a few months also. i am pretty sure you have lost your freon charge and unless you can physically see the leak with soap bubbles right at the compressor piping you are in need of a new box. good luck .
Nov 01, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Low suction pressure high head pressure
That system has a restriction. Most common at TXV valve or capillary tube. Will need to be replaced by Refrigeration company. In this video I replaced TXV valve and filter drier due to the same issue You have. Its Ice Machine, Low side was at 5 PSI, High at 250PSI : 404A; should be around 55-65 Low; 250 -275 High. Replaced drier and TXV, machine works proper.
May 19, 2008 | Hussmann Freezer 12 Facing Straight Glass...
Freezers Logo
263 people viewed this question
Top Hussmann Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Jerry Kramer
Jerry Kramer
Are you a Hussmann Freezer Expert? Answer questions, earn points and help others
