Question about Uniden PC68LTW 2-Way Radio
I can only get the weather channel but the cb side dosen't work what do you think it can be?
  • 50 Answers
You don't give me much to work with. Is the weather selector switch in the CB position? Do you have an antenna hooked up? Have you checked the SWR on the antenna? What power reading do you get when you key the mike?
Please give me some feed back.
Posted on Jun 27, 2009
The weather channels quit working on my cobra 29 nightwatch.
its an internal problem , take it to a tech and let them fix it. the board for the wx probably has jumped freq. and thats why you can't receive wx.
Apr 10, 2015 | Cobra 29 WX NW ST 40-Channels Base CB...
Pulse noise
Not sure what you mean. Can you give more info?
Feb 11, 2014 | Midland 1001Z 40-Channels Base CB Radio
Cobra CB 29wxnwst no weather?
I think you have a capacitor on the wx board thats been cut and / or removed.If it has been cut and its still in the radio all you have to do should be replace it. I think it # C608 ???
Jun 26, 2013 | Cobra 29 WX NW ST 40-Channels Base CB...
With my cobra 29 wx nw st I can not pick up any weather channels. I have the k30 antenna. Do I need a dual band antenna?
Do you hear static when you turn on weather? If so there are just none in range of you. There are not weather radio stations everywhere. You would not use a dual band antenna on any CB. Only an antenna designed for the 11 meter band. Which is the 27mhz CB radio band.
You can go here and see if you have NOAA All hazards weather radio coverage in your area.
If the CB radio is working otherwise it is most likely that there is just not a NOAA transmitter near you.
Aug 09, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 75 wx st everything seems to work eccept receiving signal meter will spike on trx and it seems to receive but no sound there is sound in wx mode
WX is for weather. If you put it on WX, and you do not hear anything, then you need to change the weather station it is on. in wx mode, you change weather channels by pressing channel up and down. To communicate with 2 way, press the cb/wx button so it is on CB mode.
Sep 28, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Twilli811@hotmail.com
check the SWR's on antenna. check microphone it has to work for the RX to be heard. cbshop
Sep 06, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Wx stations disappeared
They did not put all the plugs back in from the weather board. Part of what has to be fiddled with is underneath the weather board.
Open the bottom cover where the speaker is, on the right side you will see a board separate from the main board. Look for any plugs unplugged. Its probably one that got over looked.
If there are no plugs out, who ever you took it too may have turned something they should not have. most likely its a plug. Its probably the plug that runs the audio into the radio from the weather board. its working, the audio just isn't getting to the rest of the radio.
there are about 3 or 4 plugs from the weather board to the main board of the radio.
Nov 10, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
No cb channels no audio no recive
If you have no channel display or CB operation, it sounds like a blown voltage regulator that supplies power to the CB PLL circuit.
Sep 14, 2008 | Ranger TR-696F SSB CB Radio
NO sound
Make sure the switch is in the CB position. If this is so, then you may have a bad switching transistor or a bad diode in the board. Also on some of the weather band cobras I have worked on in the past, I have found bad pll chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 30, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cb not working
Probably cold solder joints on the stand up if boards. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 30, 2007 | Midland 1001Z 40-Channels Base CB Radio
Uniden PC68LTW 2-Way Radio Logo
85 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
