Question about Magic Chef MCBR440 Compact Refrigerator
My mini fridge will not work. compressor is hot. thanks
  • Anonymous Mar 13, 2014
    mini fridge compressor hot not running
I have the same problem as the June Post, Magic Chef Model # MCBR445S won't run and the Compressor is Hot. I do have a tester.
Posted on Aug 23, 2009
  • Magic Chef Master
  • 4,655 Answers
The first thing that I would look for is a defective start relay and start capacitor. If you are ready let me know and have a ohm meter and we can do some test. Sea Breeze.
Posted on Jun 26, 2009
SOURCE: My Magic Chef Mini Fridge just stopped but the compressor is hot.
ok In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Posted on Jun 15, 2011
caroldon
  • 17130 Answers
SOURCE: I have a brand new mini fridge, the type with a
It is possible that the setting of the thermostat is too high and that the compressor is finding it hard to reach the set temperature thereby making it work so hard so as to heat up. Now as per design this must not happen but if the thermostat or the auto defrost does not work then the compressor might be working too much and so will BURN OUT in the long run. The compressor might warm up but not HEAT.
So if the fault stays with a lower settting please contact dealer for warranty. If not this seems to be a fault with the compressor and you must stake claim for warranty.
Posted on Sep 27, 2011
erpaalai
  • 999 Answers
SOURCE: Mini Fridge not working MCBR445
Compressor is in a locked up/ no start condition. the overload cools enough to reset and tries to start it again and kicks out on amp draw, then the whole cycle starts over again.
Eric
Posted on Jul 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: my mini fridge will not work. compressor is hot.
Believe you need to change the start relay and overload, Sea Breeze
Posted on Aug 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: Magic Chef Compact Mini Fridge Model
Might just be the compressor relay. They had a bunch of them go bad in recent years. I have repair photos HERE
Posted on Jan 10, 2010
Galaxy mini fridge stopped working
The thermostat, which is also an ON_OFF switch has failed (@ 99% probability).
No, the little fridge doesn't have a pressure switch to turn the compressor off when freon is low. And no, auto freon is the wrong kind and it wont work in the little fridge. The freon that your little fridge uses is the stuff that all the fuss has been about (with the ozone layer), so it is not sold to appliance owners but only to licensed techs.
If this is helpful I hope you'll take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Koolatron Mini Fridge Compact Refrigerator
I have a brand new mini fridge, the type with a freezer as well. Its compressor has been getting extremely hot lately (too hot to touch), but it's still keeping everything cold and the freezer is still...
Sep 27, 2011 | GE Refrigerators
Frige gets hot and makes clicking noises.
Sounds like the compressor is not working very well the clicking is the compressor starter trying to start the compressor. May be low on freon or bad compressor. You can probaly buy one cheaper than fixing this one
Dec 26, 2017 | Haier Refrigerators
Aug 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Aug 23, 2009 | Magic Chef MCBR440 Compact Refrigerator
Burning smell and dead mini-fridge/kegerator
If the compressor is being used for extended times without resting or getting the product cooled, could be the problem. On small refrigerators the inside is sized for the work load. The condenser coil on back or in some cases under the outside skin of the refrigerator is designed to cool the area inside by releasing the heat from inside.. You may need to modify your cooler to handle such loads with more cooling capacity and condenser with fan to help bring the product temps down more efficiently. Let me know, Thanks, Sea Breeze
Mar 19, 2009 | Sanyo SR-4912M
Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Nov 03, 2007 | Koolatron Mini Fridge Compact Refrigerator
Magic Chef MCBR440 Compact Refrigerator Logo
2,400 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
