Question about Microsoft Xbox 360 Console
My 256 mb was showing 251 mb with all profiles and now it is showing 214 mb. what happened to all my memory?
  • 122 Answers
There could have been a System update that used a part of it, perhaps you saved a game. There are many things that will slowly eat the Built in memory on an Arcade Version. This is why I always recommend a Hard Drive version.
Posted on Jun 27, 2009
Will a Samsung 256MB DDR PC2700 CL2.5 184 PIN work
No that memory is not compatible. The Precision 350 uses memory called RDRAM aka RAMBUS.
Here are the speeds and sizes that are supported.
Memory modules supported PC800-40: 64-, 128-, 256-, 512-MB, non-ECC or ECC
PC1066-32P: 128-, 256-, 512-MB, ECC and 64-, 128-
,256-,512-MB, non-ECC
Minimum memory PC800-40: 128 MB non-ECC and ECC
PC1066-32P: 128 MB non-ECC and 256 MB ECC
Maximum memory PC800-40: 2 GB non-ECC and ECC
PC1066-32P: 1.5 GB non-ECC and ECC
Sep 27, 2014 | Computers & Internet
What is the maximum memory capacity for the MX6027 model ?
Hello Marc,
The maximum is 1 GB. Standard, it comes installed with 256 MB but you upgrade with additional 256 MB or 512 MB memory modules. The modules you are looking for are:
256 MB DDR (1 x 256 MB) SODIMM (PC2700) 2.5v SYNC
512 MB DDR (1 x 256 MB) SODIMM (PC2700) 2.5v SYNC
There are lots of places on the web to find decent prices for this memory. I have included a few below.
http://www.memorystock.com/memory/GatewayMX6027.html
http://www.pcmemorystore.com/Gateway-M_Series_Notebooks-MX6027-ram.htm
http://www.computermemoryoutlet.com/Gateway-M_Series_Notebooks-MX6030-memory.htm
This document includes instructions for replacing the memory. It's a simple straightforward process.
http://support.gateway.com/s/Mobile/Q106/Blade/8511418.pdf
Hope this helps.
Have a blessed day.
Thanks for using FixYa
Jul 29, 2011 | Gateway MX6027 Notebook
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
I want to install memory on a Compaq SR1503
The following list shows what your basic computer came with and approx what you
can go to. When ordering make sure you specify speed and type
Memory Installed 256 MB (1 x 256) Maximum allowed 4.0 GB* (4 X 1 GB) requires the replacement of the installed 256 MB DIMM
*Actual available memory may be less Speed supported PC2-3200 MB/sec Type 240 pin, DDR2 SDRAM
Oct 02, 2008 | Compaq Computers & Internet
Startup
Black Screen shows memory counting which stops at 256 Mb [is correct] Hit F10 & screen says "Setup" in bottom right hand corner-screen is still black. Floppy Drive Bay green light staying on. Regards John
Jul 10, 2008 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
When i add a memory in damaged DIMM slot showing black screen?
Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
B. If additional memory is to be used, install another matched pair of DIMMs
in DIMM 1 in both Channels A and B.
Mar 25, 2008 | Intel D865GBF Motherboard
It is slow with memory card provided with mobile 256mb.
hi ,
u can go for max512 mb..dont go 1 gb as this will hamper the speed of ur mobile..& if u switch to 512 mb..do try to keep all the stuff in memory card rather than sim memory..transfer mostly all the things from phone memory to mem card.This will sort the speed problem of ur mobile
Thanks
Gizmo1
Oct 19, 2007 | Sony Ericsson W300 Cellular Phone
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
