Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Have 12 gallon / 1HP Craftsman compressor, accidentally ran it while it was low on oil....about half way low. It shut itself off. Then, I added oil and it started up. But now it builds pressure VERY slowly and not much above I think like 60lbs. Is this motor shot? If not, what can I do to fix? Where can I find a replacement motor? Thanks!!
    Sergeant:
  • 222 Answers
Not the motor, but probably the compressor shot. Heat from friction (due to running without oil) probably scored the cylinder walls, which allows air to escape past the piston and rings, making the compressor VERY inefficient. Some compressors have replaceable cylinders... Not sure if the very small ones do or not.
Posted on Jun 28, 2009
I just bought a craftsman pneumatic 1/2-in drive impact wrench. And used it with my craftsman 4-gallon 1hp air compressor tried to loosen the bolts on my car wheel wouldn't loosen them help
Pneumatic tools are rated in cfm (cubic feet per minute). Your 1 HP air compressor is rated at probably not more than 3 cfm while the 1/2 " impact driver needs at least 8 cfm, maybe 12 chm of air.
The compressor must provide more chm than tool rating needs.
It is a problem, by the time you look at five horse power air compressors and larger, a lot of electric power is needed. A circuit of 220 volts, 20, 30, or more amps would be required to run those large expensive compressors.
If you can, return the air tool and get a good electric tool instead.
Leave those high air volume air tools to shops that are so equipped to use, or invest if you must.
Jul 24, 2017 | Craftsman Air Tools & Compressors
I have a 3 gal craftsman air compressor. Compressor runs but will not build more than 20 psi in tank reserve. Whats wrong?
if shuts down at 20 psi regulator is set wrong
it runs but only builds 20 psi, compressor is probably worn out
Oct 03, 2015 | Craftsman Air Tools & Compressors
Bought new 7 gallon 1HP horizontal craftsman compressor. Used first day worked great . Second day plug it up hit on switch and all it does is click when you cut it on and make a humming sound
does it have oil? take it back for a replaement. pull the belt off and see if the motor is still good. turn the pump by hand to check for free turning.
Apr 22, 2015 | Craftsman Air Tools & Compressors
I have a model cw0100 1hp 4gal. and need to know capacity of oil tank.
Check you model number. I don't think cw0100 is correct. Most 1HP 4 gal pancake compressors are oil-free.
Jan 09, 2011 | Stanley FactoryReconditioned Bostitch...
I have a Craftsman 3 gallon 1HP air compressor that will only build pressure up to 25psi. The check valve was checked and looks ok. The pressure regulaor appears to be working ok. Bled off tank.The...
Sounds like the compressor has failed -- probably the valve -- tear down and rebuild is probably the solution, or replace compressor, or just buy another unit. My nature would be to tear it down and see what's going on.
Mar 22, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gallon 1hp. Motor runs but no pressure buildup. Oil level okay and no obvious leaks.
Your motor is good and your pump is in need of being rebuilt. I would price both the rebuild and the cost of replacement all together as there are many good cheap used compressors crying for a home.
Aug 20, 2009 | Air Tools & Compressors
The air is coming out of the filter instead of intake . Craftsman Air Compressor 12-gal 1hp model 921.166400
if acualy exhaust / engine pressure is coming out of filter it likely to be a bad valve...does engine blow smaoke or oil? is there also pressure coming out of oil crankcase?....let me know , we'll diagnose it! good luck, marty
Jun 14, 2009 | Craftsman Air Tools & Compressors
Air leaks between head and cylinder
either the head gasket is gone or the rings are shot
Mar 04, 2009 | Air Tools & Compressors
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
634 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
