Question about Euro-Pro F1066 Deep Fryer
My deep fryer keeps turning off.
My deep fryer stays on for about 3 minutes and then shuts off. Can you help?
  • 46 Answers
Do you hear a clicking noise?if so might be over load bad or the compreser
Posted on Jun 26, 2009
American range fryer will not light...the knob you turn to light the pilot light will not turn.you can push it in but won't turn.please help
From the Owners' manual:
LIGHTING
1. Before attempting to light this appliance, the door if so equipped, shall be open.
2. Turn the appliance manual gas shut-off valve to the OFF position.
3. Turn the combination gas control knob to the OFF position.
4. Turn the thermostat control to the OFF position.
5. Wait 5 minutes.
6. Turn the appliance manual gas shut-off valve to the ON position.
7. Turn the combination gas control knob to the PILOT position.
8. Light the pilot with a match while depressing and holding the combination gas control knob until the pilot remains
lit upon releasing the gas control knob.
9. Turn the combination gas control knob to the ON position.
10. Turn the thermostat control knob to the desired temperature to turn burners ON.
11. Ensure that the door is closed during operation.
12. For complete shut-down, repeat steps 2, 3, and 4.
It won't turn any further until the pilot is lit and stays lit.
Jun 14, 2014 | Kitchen Appliances - Others
How can you tell if the pitco fryer safety switch is bad
The safety switch is operated by extremely high temperatures. If the safety switch is bad, it will not shut off at extremely high temperatures.
Jun 02, 2014 | Imperial IFS40 Deep Fryer
Bakers pride deep fryer will only stay lit for couple of minutes and then shut off
Hi there!
Normally hi limit sensing bulb is thicker and shorter than that of thermostat.
Try tightening all wire terminal crimps and connection.
Regards.
Feb 05, 2013 | Imperial IFS40 Deep Fryer
Pitco 45C- fryer lights and burns aprox. 5 to 8 minutes, then flame and pilot go out. However it will relight without having to reset anything. This info is coming from the owner and I have not seen the...
I assume that the fryer has auto ignition feature. Try to check if the hi limit sensing bulb (located inside the fry tank) is not touching the fire tube, it must have at least 3 millimeter clearance with respect to the fire tube otherwise, high temperature will be sensed that will trip (@ 450F) its mechanical contact which will in turn shut the burner operation and will reset once it is cooled down.
The same with the manual ignition fryers.
May 10, 2011 | Pitco Frialator 45C Deep Fryer
Fryer lights off, but won't turn off when the thermostat is turned to the off position
The pilot flame will stay lighted even when the thermostat is off, you have to turn the gas valve knob to off position in order to shut the pilot flame.
But when burner flame remains on after shutting off the thermostat, the thermostat's mechanical contacts are shorted or remained engaged. If this is tha case, you have to replace the thermostat.
Jan 21, 2011 | Pitco Frialator SG18S Deep Fryer
We r trying to start our fryers.. we were given them and to assistance to start them.. These are gas and we don't have the model number
On the gas valve there is a knob that has 3 positions...ON/OFF/PILOT. Put the knob in the pilot position and push the knob in and light the pilot while keeping the knob pushed in. After about 30 seconds let go and the pilot should stay on. Then turn the knob to the ON position and set the thermostat.
Tom
Aug 11, 2010 | Pitco Frialator 35CS Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Reset button keeps coming on and shuts it down.
unplug it for about 15 minutes... then plug it back in... should be fine then
Jun 26, 2009 | Euro-Pro F1066 Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Euro-Pro F1066 Deep Fryer Logo
1,165 people viewed this question
Top Euro-Pro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gerry Harvey
Gerry Harvey
Clarice Bornschein
Level 1 Expert
Are you an Euro-Pro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
