Question about GE Spacemaker 3.6 Cu. Ft. 3-Cycle Portable Electric Dryer - White
Why are my dishes dirtier when they come out of the dish washer than when they go in
  • 46 Answers
Check spray arm make sure its not pluged up
Posted on Jun 26, 2009
What causes grit to dry onto dishes after dishwasher has finished?
Check water hose leading to the dishwasher for deterioration..
May 11, 2014 | LG LDF6920ST Stainless Steel 24 in....
Indesit IDL 850 dishwasher: dishes in the top drawer ONLY are dirty: residues is left on and inside what is in the top drawer, so that they come out dirtier than when they went in. This is new: I have not...
If he Dishes Are Not Clean:
- Have you put the right amount of detergent into the dispenser?
- Is the wash cycle suitable for the dishes you have placed inside the
appliance?
- Are the filter and microfilter clean?
- Can the sprayer arms turn freely?
This is how the manual helps.
Jun 29, 2017 | Indesit Dishwashers
Dishes are always dirty, maybe even dirtier after running dishwasher. has hot water, lower arm moves.
Check the outlet holes on both spray arms for clogs. If necessary, remove the spray arms, clean out the holes and empty out any debris inside the spray arms. Verify that the upper arm is turning also.
If the machine does not drain completely at the end of the cycle, the pump drain outlet is partially blocked and you are retaining dirty water for the next load.
You may have a chemistry problem - inferior soap, empty rinse agent dispenser, or extremely hard water.
Improper arrangement of the dishes can prevent some from being washed. Make sure no dish blocks the spray to another.
Jul 23, 2011 | Dishwashers
Why is my dish washer leaving food on my dishes that i loaded rinsed off?some dishes come out dirtier than i put them in there.
It is almost always because you have blocked the hole where the sprayer goes up through the middle of the dishwasher. If it cannot pop up the dishes will not only not clean, but the food will just deposit onto the dishes especially the upper rack.
Sep 30, 2010 | GE Crock Pots & Slow Cookers
I have used dishwasher cleaners, use Cascade Complete dishwahing detergent but all of the sudden, my dishes come out of the dishwasher dirtier then they went in. The glass glasses have a gritty stuff...
depending were you live they changed the formula in cascade,but they are doin a new formula are you using a rinse agent? claean the machine clean spray arms and soap dispencer,with no dishes run machine with 1cup of CLR or 2Cup of vinegar just pour in tub and let it run full cycle no drying.Thanks
Jul 31, 2010 | Whirlpool Dishwashers
Dishes not rinsing well,
I would check the bottom drain area. Sometimes food can stay down there and block the drain or get back around onto the next load.
Apr 06, 2009 | Kenmore Dishwashers
Not cleaning the dishes
You need to check your water temp after it enters the diswasher, it should be at least 120 deg when it get in the dishwasher. If it not then the detergent, food, and greese can't break down.
Jun 20, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Chunks of Junk on my Dishes
It is likely the drain into the side of the disposer has become clogged . you have to disconnect the rubber hose and run a twisted wire up into the hose and be certain the hole into the disposer is clear, seal the hose back with some silicone as it is old and cracked likely or just watch for any hose leaks .
after that the drain should **** all debris clear.
if not do it again but use a water hose to back flush the drain.
and a bit of bleach in all your washings to break up the mold inside the pipes and keep the dishes clean.
Mar 09, 2008 | Dishwashers
Dishes dirtier after washing
start machine, do you hear water running in?? place 4 cups upright on all four corners of top rack, let it run for a few minutes ,open door are the cusp full?? or atleast filling???. if not you have a water issue
Feb 20, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
GE Spacemaker 3.6 Cu. Ft. 3-Cycle Portable Electric Dryer - White Logo
56 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
