Question about IBM Computers & Internet
What numbers off the HD do I use to set up the CMOS on the mother board under "User" hard drive?
    Problem Solver:
  • 6 Answers
Use automatic detection if it is available; if not use the following:
Size: Usually set automatically depending on the settings for heads, sectors, and cylinders.
Cylinders: The number of cylinders on hard disk. Should be written on drive.
Heads: Number of heads. Should be written on drive.
Write precompensation: Not much used on modern drives. It was used to accomodate drives that had the same number of sectors per track, including both the inner and outer tracks. On SCSI drives
, set this to -1. On IDE drives, it is not necessary to worry about it as it will be determined automatically.
Landing zone: Used for drives that don’t have auto-parking. All modern drives do, so just set to 0.
Sector: Number of sectors per track. It’s often 17 for MFM drives, and 26 for RLL drives.
Posted on Jun 26, 2009
Need bios password?
Thats why they tell you not to save the information on a file on your hard drive. You should have it written down. I bet you won't make that mistake again!
May 29, 2014 | Acer AZ5771-UR21P 23-Inch All-in-One...
Toshiba Satellite L355D-S7815 re-soldered cmos battery onto mother board and re-set the bios, now I have the f2 and f12 option available, tried to boot cd/dvd drive with windows 8 disk and it will not
Go into the BIOS setting abd check it the BIOS detects the hard disk and CD/DVD drive.
If it detects these drives then go to the boot device order and select the CD as the first boot device then the hard disk as the 2nd boot device.
Apr 03, 2013 | Computers & Internet
I forgot my password of buffalo HD-PX320U2 and hint. please help me out. i do not want to format my disk.thanks
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
Hope this helps
Jul 17, 2011 | BUFFALO hop 320GB MINISTATION METRO(...
Hello, we drop the laptop on the floor, and then the hard drive (wdc WD1600bevs-07rst0) began to demand a password when starting the laptop. after 3 attempts to say "ask for the master password...
theres battery it looks like a watch batter make sure its in the mother board all the way make sure your fuse is set in place all the way then start up it ask you to push f2 push f2 then change your boot formate to f12 with arrow key on key board you see it set already on f2 change it to f12 the push f10 escept it then restart lap push f12 then when asked rerun windows.
Feb 16, 2011 | Western Digital Scorpio WD1600BEVS 160 GB...
How do I fix OS does not see hard drives - MSIK8T NEO mother board raid 0
1. Reset the Motherboard by either removing the CMOS battery or the CMOS jumper and putting them back.
2. Go to your BIOS settings and check if the settings are right or even restore to default.
3. Check the cables ( This is a common problem)
Hope this helps
Dec 30, 2010 | Intel Motherboard
My mother board DG41RQ is not detecting any hard disk drive
Here are two locations in delhi;
Upper Ground Fl, Block E
Int'l Trade Tower, Nehru Place
New Delhi
Delhi 110 019
India
21 Nehru Place, Suite 311
Paharpur Business Centre
New Delhi
Delhi 110 019
India
Jan 27, 2010 | Intel DG41RQ Motherboard CPU Bundle - ...
Why litium battery in mother board(intel,asus)?
The lithium battery is use to power up the RTC/CMOS chip which stores the date and time, and some essential configuration settings for your motherboard. If you notice that your computer clock is not displaying the proper date and/or time after you set it correctly, then you may have to change the battery.
Nov 25, 2008 | Intel Motherboard
I replaced mother board now I can't access files on old HD
Try going into the BIOS settings and setting the slave drive as the 1st boot drive.
May 04, 2008 | Intel Motherboard
Password for 486
Remove the battery from the mother board.
Jumper the CMOS to discharge it. You may
want to check you Mother Board manual, to
see which jumper it is. Some require you to
turn the Mother Board BACK ON for two seconds. (It will NOT come up, just will
discharge the CMOS and the battery will NOT
be there to replace the energy, so everything
is GONE. You will know if you have done it right, when
you boot up again, the BIOS will NOT recognize the hard disk (need to set it up
again), the date will be wrong (set it up again also) and the floppy drive will not
be recognized (new setup). But then try your password. It should let
you right in then. Let me know if it works. Best Regards, PS Make sure you have the right mother
board jumpers to discharge the CMOS, YOU
CAN DO DAMAGE ALSO, if they are not the
right ones.
Jan 25, 2008 | Grandstream HandyTone 486 ATA (HTATA486)
Cannot boot in Slave mode
i have never heared of any hardrive being able to boot when it is set as slave, as the master is always the 'C' drive from which windows looks for the master boot record. why, if you have only one hard drive is it set as slave?, it doesnt make sense. No hard drive will boot up if there is no jumper cap on it, as the motherboard needs to know which hd is master and has the o.s on it.
Jul 28, 2007 | Asrock P4I45GV R5 Motherboard
Computers & Internet Logo
1,340 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
