Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Replaed lamp and it won't power up. fan is on but
Replaced lamp and it won't power up. fan is on but no lamp. also lamp light continues to blink. worked fine after replacement for a couple of hours, turned off and left for a couple of hours and thats when it stoped working again.
  • chip2hole Jun 27, 2009
    No i wouldn't say that, at least it was worth a try. Just can't understand why it worked at first and now won't power up. as i said the fan is running just no lamp?
    Thanks for your help, I di check the door switch and it appears to be working fine. I think it may be the ballast? again thanks for your help and i was not being critical of your help tip i just responded to the question.
  • 10,594 Answers
Please check lamp door that seems not fixed / seated properly. Lamp door / cover push a safety switch that is not being pressed and causing no power up of TV.
Posted on Jun 26, 2009
  • Shahid Electronics
    Shahid Electronics Jun 27, 2009
    TV would not say to check its lamp cover.
    You just replaced lamp and obviously lamp cover was removed. I already explained it to you that there is safety switch that is pressed by lamp cover. Check lamp cover again instead of rating me Not-Helpful.
    Shahid Electronics Jul 12, 2009
    OK, here is another info about your TV problem.
    Its ballast supply need to be repaired and there is repair kit available in partstore.com
    Let me know if problem has not been solved to provide you more info about ballast repair.
My Sanyo tv is not working. The power light comes on and then starts blinking red.
I myself had a 55 inch hdtv ready projection tv and the lamp went out in it. It cost me $104.00 plus shipping to replace it. Check out discount replacement parts but remember that if it is a projection tv, it won't last but approximately two years and you will have to do it again.
Aug 25, 2012 | Sanyo SELECT PLC-XP45 Rear Projection...
Epson 84+ green light blinks no light
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
May 21, 2012 | Epson Corporati PROJECTOR, EPSON,...
I have an Infocus SP 7200 projector that will turn on, fans run and the color wheel spins and the projection lamp blinks briefly on for a second but then straight away the color wheel winds down and the...
Color Wheel could cause this, it must spin exactly 9,000 rpm per second ,but so can having a bad ballast board it is what powers Lamp on, If you still have the old Lamp and your sure the Lamp was Bad then reinstall old lamp and see if their is an ark coming from Spark Gap on the Ballast Board,
If you see an ark then Ballast is OK.Heres another thing watch the Lamp Fan if it is defective Lamp will not power on, If the Lamp Fan stops when Lamp trys to firer,then replace the lamp Fan.
Jun 29, 2011 | Televison & Video
InFocus ScreenPlay 4805 no projection. Unit powers on and green light blinks, but no light and no fan, eventually red light blinks continuously about 2 seconds between blinks. When the green light is...
the high-pitched sound is the colorwheel trying to spin up to speed. that may need to be replaced. check the inside of the lamp for bulges, black spots, fogging or flaking. if it has any of those, replace the lamp. you can get parts from an infocus service center or send it to them for repair. either way, try www.avsolutionsny.com they're really good. if you want to replace it yourself, there is a detailed step-by-step on my "tips" area. it's the same as the infocus x1, x2, x3 and sp4805. click on my picture and scroll down to tips. good luck!
Feb 01, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
3 flashing lights after replaing lamp
check the lamp connection and also to insure you have the correct replacement lamp for your model. as 3 blinking LEDs mean lamp may be defective.
May 25, 2009 | Samsung HLP6163W 61" Rear Projection...
Sony- KDF-50E2000
Have you replaced its Lamp?
Symptoms shows TV needs new lamp.
Please always buy original Sony lamp for replacement.
Mar 15, 2009 | Sony KDF-E502000 50" HDTV
Buzzing/screaching noise when turned on, standby light blinks and then lamp light blinks
It sounds like a bad lamp. Replae the lamp firts, but there is a chance you have a bad lamp driver also.
Oct 21, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
297 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
