Question about TitanNet Vaper 41181 90 Amplifier Wire Feed Welder
Where can I buy replacement parts?I need the Diffuser and the nozzle .
  • 3,600 Answers
Try this site here http://www.justtools.com.au/prod1770.htm if they don't have what you need post to this answer and I will look for different site for you.
Posted on Oct 06, 2009
No gas to the tip, have it to handle
Hi:
If the gas is not going thru the nozzle but exist at the gun's handle, your problem must be the gas diffuser (contact tip holder), this one must be all obstructed. You did not mention what gun brand is it or what kind of welder it is but try changing the gas diffuser it a cheap item, less than 8 bucks.
Good Luck.
If this was useful to you please vote.
Mar 01, 2011 | Welding Tools
How do u change the liner in a lincoln mig welder
Hi:
That's an easy one. First unplug power cable and remove the gun from the machine.
a. Lay the gun and cable straight on a flat surface.
b. Remove and save the gas nozzle and nozzle insulator.
Make sure that the set screw in the gas diffuser
is backed out so as not to damage the liner.
Use the 5/64" (2.0 mm) Allen wrench provided with your new liner.
Remove and save the gas diffuser from the end of
the gun tube assembly. Remove and save the liner
nut from connector end.
c. Remove old liner and insert a new untrimmed liner
into the connector end of the cable. Be sure the new liner
it's appropriately for the wire size being used.
d. Before installing the gas diffuser, fully seat the liner
bushing in the connector end and install the liner nut
and finger tighten.
e. Be sure the cable is straight and then trim the liner (all new liners are over-sized and need to be cut to your gun lenght) 9/16" to 1" over sized to the length of your gun without the tip holder. Remove any burrs from the end of the liner.
f. Screw the gas diffuser (tip holder) onto the end of the gun tube
and tighten with the wrench provided.
g. Tighten the set screw in the side of the gas diffuser
against the cable liner using the Allen wrench provided.
h. Replace the nozzle insulator and gas nozzle.
That's it. If this was useful to you please vote.
Feb 23, 2011 | Welding Tools
The light diffuser cover is broken. The model number of the range hood is HO60488. The range hood dates back to possibly the late 1950's when the house was built.
When faced with the total unavailability of replacement parts, its time to get creative, and make your own diffuser cover. Flat ones
can be easily made - find anything plastic that's semi-translucent (like a plastic milk bottle), and cut it with a utility knife.
I have also used a utility knife to cut a polystyrene diffuser cover
originally intended for a 2-ft x 4-ft suspended ceiling fluorescent light fixture.
In case the diffuser cover you make wants to burn when placed close to a light bulb, replace the bulb with a CFL (compact fluorescent) bulb, which run MUCH cooler than incandescent light bulbs.
Old lampshades can be cut and used, but may need to be ironed flat. The major advantage of lampshade material is that
it can be folded over at the edge once or twice, which will fill space - and possibly hold the cover where a plastic sheet might be too loose.
You'll know that your efforts have met with success when you can easily remove your ne diffuser cover to replace the light bulb.
Feb 20, 2011 | Venmar Kitchen Ranges
Need new fresnel lens for vivitar 285
Cheapest solution is insert accesory 28 mm Diffuser in its slot(in the front of Tube).
Or buy defected Flash from ebay for this part.
Oct 27, 2009 | Vivitar 285HV Flash
Braun espresso machine replacement part
If you are unable to get the part directly from BRAUN by calling 1-800-272-8611 (if your machine still falls within the warranty they will usually replace it for free) then I would recommend that you try Ebay as corny as it sounds because you could likely buy a used/new set for not much more than you would pay for the "ordered part" from replacement part sites.
Here's an example: http://cgi.ebay.com/VINTAGE-BRAUN-Coffee-Cappuccino-Maker-MODEL-3062_W0QQitemZ110253282082QQihZ001QQcategoryZ38252QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Also, if Braun no longer carries the part you need you could also try asking them if they have a diffuser from a different model that would work with your machine.
Good Luck!
May 19, 2008 | Coffee Makers & Espresso Machines
TitanNet Vaper 41181 90 Amplifier Wire Feed Welder Logo
313 people viewed this question
Top TitanNet Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a TitanNet Air Tool and Compressor Expert? Answer questions, earn points and help others
