Question about Acer Computers & Internet
Computer loads...screen stays black ...help! - Acer Computers & Internet
  • repeat_2000 Jun 26, 2009
    alright, i suppose that you may need some more info... uhhh. the model number is Acer aspire, 5520-5806, unfortunatly i dont think it is the Lcd as i hooked er up with some Sctv cables too a moniter that i know worked, and there is still nothing showing up.... the only thing really out of the ordinary that has happened in the last while was that i accedently left er plugged into a power bar and left... and then my roomates disconnected and reconected the power bar.... should i try making a boot disk off another computer or something ?
  • 721 Answers
Not knowing the make or model... or what happened before this issue. I'm gonna say replace the lcd & inverter.
Posted on Jun 26, 2009
  • Pete MacSparran
    Pete MacSparran Jun 27, 2009
    Dude,unfortunately you have a bad video card or module built into the board bad. If there's no video out of the vga port to a external monitor,you got a problem.
What would cause computer not to turn on when the power is loaded and the screen to stay black?
Im sorry about your situation.
Does the computer turn on??
If the computer turns on do you hear or can you see the fan working??
If the computer turns on does it stay on or does it shut down after a few minutes??
This will help us determine what is going on.
May 31, 2014 | Acer Computers & Internet
Screen went black...rebooted, computer seems to
Remove the battery and disconnect the power adapter for about a minute.
connect only the AC then boot it back up. If you can see the Compaq splash screen and still unable to load Windows, re install OS.
If you could not see the splash screen, too bad it could be a motherboard issue,
Hope this helps.
Dec 21, 2009 | Compaq Presario CQ60-220US PC Laptop
Installed still life and it wont play , it says game is running
Find the program in the installation directory. It might be something like C:\Program Files\The Adventure Company\Microids\StillLife
Now right-click on Stilllife.exe, then click Properties. Click the Compatibility tab, then select Windows 98/ME from the drop down menu. Hit OK and try to run the game again. It should start up just fine.
May 29, 2009 | Microids Still Life for Windows
Windows starts to set up then screen goes black and
sounds like you have a heating problem I need More information to help you, try pulling the side off the pc and blow off the cpu fan with compressed air for a computer store also blow out the monitor as best you can, next start up the computer but go into safe mode by pressing F8 before windows loads load without networking if it works there and does not turn off you have a driver problem after performing the first two suggestions if it stays on reboot hit F8 again before windows loads and click load in safe mode with networking then go to Microsoft's help page it's http://www.microsoft.safety.clean and run their cleaner if it detects a bug remove them then go to microsoft support and download the latest drivers next defrag the computer in safe mode then go to www.drivers.com and run scan for driver updates there it will give you a list of out of date drivers for your entire computer save the screen in word by using the ctrl V and ctrl p and then reboot normally and if windows stays on go to the driver site and down load all the latest drivers, next go to male-ware bytes and download their free trial software and run a scan on your computer. The latest virus has did ansi bombs with Delaware and worms and has killed your monitor drivers once you run the male-ware and remove the virus's and worms reboot to safe mode do disk cleanup and then do disk defrag in safe mode. good luck.
May 28, 2009 | Sony VAIO VGC-RB42G PC Desktop
The screen turns black and stays like that
Normally it's because the resolution is set too high for the monitor. This has happened to me when I switch a computer from a flat screen to a old "biggy-size" monitor.
try rebooting the computer and BEFORE you see the windows splash screen, start pushing the F8 key...this should bring up a menu...select VGA Mode...it won't be pretty, but once you're in..right click on the desktop and change the solution (try 800x600). restart the machine...that should work.
-SuperDale
May 05, 2009 | Apple Computers & Internet
When i get to the loading screen on disk 2 it gets stuck on a black screen. i tried cleaning both the console and the disk but it still gets stuck on the black screen
Alot of the newer playstation console's won't read the old black or blue labels. Try getting it resurfaced. Cost you about $2 at the nearest game store.
Apr 25, 2009 | Sony PSone Console
Black screen after fresh install xpmc 2005
Are you able to go windows safe mode if yes ... Start > Run > Msconfig > Ok
in the general tab you have option to seleect Normal Start up > Click on apply and ok and restart yiur computer that should work
Apr 09, 2009 | Microsoft Windows XP Media Center Edition...
Screen seems to be not working properly
try using a different monitor, borrow one if you have to, if the monitor works on your computer, then it simply means you need a new monitor. As far as the computer shutting down, it may be recording the bad monitor as an error in the loading process and automatically shutting down.
Mar 15, 2009 | HP TouchSmart IQ770 PC Desktop
Lights turn on when starting up but screen stays black
Reboot and hold down the delete key to open the bios. Reset the bios to default settings then see if that fixes it. If not you may have to reload the computer to its factory load.
Mar 01, 2009 | HP Pavilion dv9000z Notebook
Computer won't load. blank screen.
- Press F8 during the boot,
- go to Safe Mode,
- After Desktop is displayed,
- restart the system in Standard Mode
If the problem is still there, you need to reload the Windows with Recovery CDs.
Dec 11, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
