Question about GE Refrigerators
The circulation fan in my freezer runs almost continuously, cycling between full speed for a few seconds, then half speed for a few seconds. Makes a constant 'hoot' noise when running at half speed. I would think the fan should not run this much. Are these fridges equipped with variable speed fans, or is this a pre-failure symptom. Is it possible that this could be caused by a blockage in the air path (the fan seems to be pushing air just fine). Both fridge and freezer sections cool fine.
  • tom_bryan1 Jun 27, 2009
    Sorry. It's a GE Model # GSS25IFRF WW. Side by side fridge/freezer.
  • 46 Answers
What kind of ref is it ?
Posted on Jun 26, 2009
Does the engine cooling fan run continually
No the cooling fan should run continuously.
May 11, 2014 | Ford Fiesta Cars & Trucks
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Hey there, I have a Westpoint NOFROST De Luxe Tropical frige, model # WRK 297.1. The freezer section is forming ice and the circulation fan is making alot of noise due to ice being formed behind the back...
I believe your problem is the defroster circuit . There are only three components on most refrigerators unless you have something real special . Kidding . They are as follows : defrost timer , heating element , and defrost cut out switch . The defrost timer cycles the refrigerator out of normal operation and into defrost mode once every six to eight hours depending on the unit . When in this mode everything shuts off , compressor , circulation fan , and condenser fan is so equipped . To eliminate the circulation fan , you'll have to keep an eye on your refrigerator checking in every half hour or so for six hours to eight hours and see if it stops working . If it does , then we know the timer is working correctly and the problem will be the heating element or cutout switch . The heating element is checked with an ohm meter. Usually they burn out when they go bad and you will read infinite resistance. The defrost cutout switch should read 0-1 ohms when the freezer temperature is 40° F or lower. If the heating element checks good , in other words it shows to have resistance usually between 30 and 100 ohms, replace the cutout switch . If the circulation fan never shuts off and the unit continues to run without shutting down after a six or eight hour Time cycle , replace the defrost timer . Good luck
Feb 22, 2011 | Refrigerators
GE refridgerator fan speed changes constantly
I will try to answer your question . Your refrigerator had 3 thermistors in the refrig side , and 2 in the freezer side . These thermistors , send resistance messages to the main control board , mounted on the back of the refrigerator . If say #1 thermistor tell the board , I need to be colder , then the board will tell the damper ( small vent in the top of refrig section ) , to open . If the #2 thermistor tells the board , I need to be colder , then the board tells the fan to speed up , to get more air to the refrigerator section . #3 thermistor , works with the turbo cool switch , turning the fan to a high speed also . If the thermistors tell the board , we're all fine , then the fan will slow down , but still circulate to make/keep the freezer colder . If the freezer thermistors say , we're ok also , then the refrigerator will cycle off , until a thermistor asks to be cooler again . The fan works off D C voltage , in which fan speed is regulated (faster or slower) , by the thermistors "talking" to the control board .
Sep 12, 2009 | GE Refrigerators
The bottom half of the fridge/freezer is cool, but not the top half. What's wrong . This is a side by side.
The evaporator fan inside the freezer usually behind the back panel circulates the cold air and blows it into the fridge. Make sure it's running when the compressor runs. And make sure the fan can blow the air into the fridge through the vent.
Sep 05, 2009 | Refrigerators
Can't get temp in fridge to go below 50 F. Freezer works fine and makes ice. It started when our area had a heat wave and the inside of our house was 85+ most of the day. The ice maker stopped working,...
Have you checked the evaporator fan(freezer fan), This problem is hard to detect because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator.
Aug 01, 2009 | Refrigerators
Manitowoc SD 0852A ice maker compressor will not kick-in
Here's my thoughts, I hope it helps. I'm going on foggy memory here, so I may not be entirely correct.
I worked on something like this a few years ago. The icemold (plate) is vertical, there is a circulating pump that runs water over the mold, with the water freezing as it passes. The sealed system is a heat-pump scheme, it freezes the mold to form the cubes, and reverses to heat for release. And when it works, it makes ice fast. It runs constantly until the ice hopper is detected to be full. (there should be a bail to detect the ice level) The system will not run in the event that it thinks the hopper is full (bail up) but the pump motor runs continuous to avoid it freezing. There is probably either a false detection of "full" or there may be a leak in the sealed system and the system will therefore not run.
Jun 28, 2009 | Freezers
I have a Domestic 2804 frig in my RV, The freezer works great but the frig part will not cool at all, can you help
All cooling takes place in the freezer. The refrig/fresh food side is a parasite, depending on cold air circulation from the freezer side. The fan in the freezer provides that circulation, and usually the freezer control setting determines how much air is moved into the refrig side.
If the fan is up to speed and the both controls are set in a middle position, the refrig side should be fine. if the problem continues, replace evaporator fan motor or clear the blockage preventing circulation (usually frost build-up from a defective defrost system part or blocked defrost drain).
Jun 13, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Fan slows to about half speed when heat cycle kicks in
The heat fan speed is slower than the cooling speed. About 300 rpm less.
You may not have a problem.
May 20, 2009 | LG Heating & Cooling
Refrigerators Logo
315 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
