Question about HP LaserJet 3030 All-In-One Printer
Unable to scan,, unable to find toolbox software
    Problem Solver:
First you need the software to scan. If you do not have it go to this link and select you operating system (ex: Win Xp, Vista, etc). This is needed for XP, Vista should auto find it and install itself. If not down load the print driver option and Vista should do the rest.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=378058&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=378056
For XP (anything else ask and I'll try to help, Vista see above paragraph) Scroll down to "software" Click on the one for America, download and follow promts.
I would recommend on the first screen after you download it to tell it to extract to a fold (default is c:/3xxxam), not the temporary directory or you will probably have to come back and re extract it again to a real directory. (I already went through that issue, that why I am recomending the c drive directory option, not the tempory directory). Just follow prompts, it is a slow process.
You did not say if you added it to a network or not (I am guessing no, since you couldn't find software, which means you probably do not have an external network print server, which is required to add directly to the network for this model). I am going to go with it is a direct connect via USB, so just follow the direct connect options when you get to that point and once your done, check your start menu for the hp folder, that is where you should find the scanner software.
Posted on Jul 01, 2009
  • 27 Answers
Uninstall/reinstall the printer software
Posted on Jun 29, 2009
When i try to scan i get this message: unable to open TWAIN source Please check connection then re-start Toolbox the connections are tight
Driver mismatch - the driver of the scanner has forgotten the location of the TWAIN driver because another software has been using it lately. Follow this
http://weblogs.asp.net/jeffwids/archive/2009/11/02/canon-scanner-unable-to-open-twain-source.aspx
Feb 20, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
I get an error message when I scan. It says Error
ISSUE: The error Waiting for PC is displayed on the control panel when scanning, using the Start Scanbutton on the control panel. The user will also notice a Not Setup on PC error when pressing theScan to … button. Note that scan from the PC works properly without an error. SOLUTION: The probable causes for this issue are listed below:
  • Firewall denying access to PC
  • Device polling not enabled
  • The scan to function is not enabled in the HP Toolbox
  • The destination has not been added to the Scan to button from HP toolbox
  • The HP Toolbox is losing the scan to destination
How to troubleshoot this issue:
  1. PC protection software such as firewall software may prohibit proper communication between HP AiO products and Toolbox and scanning software. Firewalls may need to be reconfigured to allow Toolbox to communicate with the AiO. The Toolbox software is similar to Microsoft Outlook and Internet Explorer in this way. Temporarily disabling firewall software may be helpful in determining if it needs to be reconfigured for Toolbox to operate properly. Please contact your third party firewall software vendor if assistance is needed to reconfigure the firewall. The following third party support Web sites may be useful:
  2. When Device Polling is turned off, the Alerts and the Scan to e-mail or folder options in the HP Toolbox are disabled, and the START SCAN function on the HP LaserJet AiO product control panel is also turned off. CLICK HERE for instructions on how to turn on Device polling.
  3. To program the device SCAN TO ... button, view the device settings. Open the HP Toolbox and click the Scan to tab. For more information, CLICK HERE to view the document titled HP Color LaserJet 2840 AiO Series Products - How to use "Scan To E-mail" or "Scan to Folder" from the Device
  4. The User loses the folder when choosing to save scanned files under the Scan to Folderoption of the Scan to Tab. The User also may lose the email settings under the Scan to Emailoption of the Scan to Tab. The User restarts the toolbox and it works for some time and the problem repeats again. Perform the following in the order listed to resolve this issue:
    1. Run the Fix Scan Utility and see if it resolves the problem. Click here for the Fix Scan Utility at http://www.hp.com If not, proceed to the next step.
    2. Check the firmware version and make sure that it is up to date. print a configuration page to see what the current firmware version is. Compare it to the latest version offered on HP.com Click here for HP.com at http://www.hp.com . If it is not the latest version then upgrade it to the latest version available on the web.
    3. Download the Software Update Version 3.0 from HP.com and install it. Click here to download the software update from http://www.hp.com
  5. For Toolbox Reset Persistent Data issues, CLICK HERE to view the document titled HP Color LaserJet 2800 All-in-One series - Toolbox Reset Persistent Data
  6. If the issue persists, uninstall and reinstall the printer software. CLICK HERE to view the document titled HP LaserJet 2820 and 2840 AiO Series Products - Uninstalling or Removing the Printing Software and Shared Components
Apr 07, 2010 | HP LaserJet 3015 All-In-One Printer
When I try to scan with my canonscan lide 70 I get a message "specify the program where the scanned image is transferred"
You just need to point the program to where the scanning program was installed. If you just let it auto-load it should be here: (assuming you loaded the free toolbox software)
C:\Program Files\Canon\CanoScan Toolbox Ver5.0\CSTBox.exe
or just look at where the toolbox is installed by searching for the CSTBox.exe file.
Mar 06, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Can't copy or scan on canoscan lide 25
You need to install the software drivers You need BOTH programs installed on your PC, Toolbox & Scangear. Also use the driver remover first. Then unplug scanner, reboot, install Scangear first, and toolbox second, then reboot, when at desktop next time, plug in the Scanner. Hopefully it should be all good. Read the Help file. http://software.canon-europe.com/products/0010219.asp
Feb 17, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Connot make a pdf scan. get a reply thet there not enough space. installed latest drivers. working with xp
Issue: ERROR: Insufficient space on target disk
Solution: Change where temporary files are saved (Toolbox)
Change where temporary files are saved (Toolbox) For an unknown reason, the computer is not allowing temporary data to be written to the general folder chosen by Toolbox at the time of install.
  1. From the CanoScan Toolbox, click the Settings button.
  2. At the bottom you will see a section that states, "Select Folder Where Temporary Files are Saved:".
    Click the Browse button.
  3. Browse to a folder, such as C:\Temp, and then click OK.
  4. Click OK again to exit the Settings window.
  5. Try scanning again.
Sep 13, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Can not scan. keep receiving message "unable to open file".
try to reset the file link (toolbox CS -> settinf -> save -> image file) where the scanned file will be saved.
Apr 16, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Your post for CanoScan LiDE 25
Hi there, yes I did everything per your instructions, Toolbox is installed and it still says, "release the lock switch, detach I/F cable and reconnect. Scanner driver will be closed" and then after clicking on that it says "Unable to open TWAIN source. Please check connection then restart toolbox" I have been to the Canon site and downloaded driver sites and it says everything is working. but when I go to scan it comes up with the boxes I said before. Quite lost at the moment? Thanks Maureen. PS I have unstalled and reinstalled
May 22, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Have uninstalled and reinstalled software for CanoScan LiDE60 and still coming up with 2 error messages - "cannot communicate with scanner" and " unable to open TWAIN source". How do I...
Are you scanning from Toolbox? Make sure the correct scanner is selected in the Settings section.
What OS is this? Try scanning from various applications.
Does the scanner react at all at any time?
Make sure you have installed ScanGear and not just Toolbox.
Apr 30, 2008 | Canon CanoScan 4400f MultiFunction Color...
Canon 440f won't scan
I had exactly as described on my new 4400f scanner. Have resolved by uninstalling the toolbox software (it was at 5.0.1.2), downloading toolbox s/w from canon site, file name is S6A04mux.exe - toolbox 5.0.1.1 Installed this and all works from the scanner front panel
Jan 06, 2008 | Canon CanoScan 4400f MultiFunction Color...
Lock Switch and IF cable
Mine was doing the same thing. When I get on the program, before I click "acquire" to preview and scan, I click OFF the toolbox and then everything seems to be okay and I can go ahead and scan.
Nov 27, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
HP LaserJet 3030 All-In-One Printer Logo
579 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
