Question about Hayward 1.5 Hp Northstar High Performance Pump
Pump stopped woking when I turned it off to backflush
The pump stopped working when I turned it off to backflush - When I tried to turn it on it sounded like a buzzer at a basketball game.
It did feel hot to the touch - maybe something did get caught inside while backflushing
  • 110 Answers
You have got stuff in your impella.
Take pump away from pipes and 'elec' power lines - empty skimmer filter inside pump - turn over and remove all 'stuff' from inside skimmer filter section.
If you can - turn impella using knife or screwdriver see if it runs smooth and silent.
Posted on Jul 07, 2009
How do i fix stop light and turn signal went out at same time?
Can you give me some more info please
have they stopped Woking on one side or both?
if one side do any of the other lights on that side work?
the most common fault if more than one light stops working is the earth wire is loose or broken
Sep 14, 2014 | 1997 Chevrolet Lumina
Tip
Proper way to backflush a Rancilio Silvia.
Rancilio does not recommend backflushing the Silvia. Sometimes we have to.
First remove the brew head screen. Clean the brew head screen and reinstall. The proper way to back flush is to use a blind basket. Place some Cafiza, or Joe Glow (espresso machine detergent, a level teaspoon) in the blind basket. Insert blind basket in the portafilter and insert the portafilter in the brew head. With the machine warm, turn on the brew switch for about 4 seconds. If the pump starts to get quieter, turn the pump off. Wait about 1 minute, and repeat.
Do this about 5 to 10 times until the 3 way valve runs clean. Rinse the basket and repeat about 5 times to rinse machine. Remove and brew some more through the brew head.
Never let the pump get quite when running the pump, while back flushing. This can damage the pump.
on Jan 01, 2010 | Coffee Makers & Espresso Machines
I have La Mazocco 2 group and when backflushing,
Machine is saying it cannot get water, turn knob to 0, wait a few seconds and make sure water is turned, then turn it to 1, wait 20 secs, then turn it to 2.
Apr 12, 2010 | La Marzocco Linea Group 1 Espresso Machine
Jandy Aqualink RS4 randomly turns on blower, pump, heater
I have has to deal with the same problem and have found that the spa switch is causing the problem. When I went into the lockout controls menu and locked out the spa switch I no longer had the problem. Once I figured this out and determined the spa switch was faulty I replaced the spa switch and everything is work correctly now.
Oct 09, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
The tank pressure is at 60
I don't have that particular brand, but it is not good that the PSI is that high. Backflush for at least 3 cycles of 60 seconds each.
example: Turn off pump, move to Backflush turn on pump for 60 seconds. Turn off pump, switch to rinse, turn on pump, run til water runs clear.
Repeat 3 cycles. If the PSI still doesn't lower, you may have broken laterals in the bottom of the sand and will need replaced.
Hope this helps. Good luck!
Jul 24, 2009 | Hayward SAND FILTER, PRO SERIES
1986 Volkswagen Cabriolet turn over but not fire
replace fuel pump relay & check ground connection at steering column
Jan 22, 2009 | 1986 Volkswagen Cabriolet
My t10 stopped working after i left it on hold for 15 minutes
just call customer service and ask them if they can repair it. I did and mines is working again. Plus you don't have to pay anything!
Jan 20, 2009 | Samsung YP-T10 Digital Media Player
Water dispenser wont shut off
Something from the filter went into the dispensor valve and is holding it open. You can try to backflush it with a can of air by disconnecting the filter pushing open the valve while holding the can straw tightly while discharging it. You could also backflush it with water.
Jan 12, 2009 | LG LRSC26910 Side by Side Refrigerator
Hayward 1.5 Hp Northstar High Performance Pump Logo
207 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
