Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
Water volumn is very low, hot or cold. Barely a
Water volumn is very low, hot or cold. Barely a stream. Sprayer has adequate volumn though
  • bedwards1201 Jun 27, 2009
    Already had tried that.
  • 67 Answers
Take the aerator off the outlet or spout, it's clogged.
Posted on Jun 26, 2009
NEW faucet! Low stream from both hot AND cold. Sprayer works well with both hot and cold. Doesn't make sense.
unscrew the end of the faucet and clean the filter and screen is probably stopped up
Nov 29, 2015 | Plumbing
Samsung lcd volumn ok with dvd very low with tv only
What is it connected to when the volume is low? How is it connected
Feb 06, 2013 | Samsung LN-S3251D 32 in. LCD HDTV
Boiler recycling when in DHC mode and water alternates hot then cold, back to hot every few minutes. Could it be pressure / flow rate.
First check pressure over 1 bar ok then-
1. check flow - is it adequate - a little less than the cold tap ok then -
2. does the boiler initially fire up on low hot flow but alternate as u say
If answers are 1. no but 2. yes then check for a furred up secondary heat exchanger
if 1. yes but 2. no [that is the water not the heating] goes hot / cold and if the boiler goes out when the water goes to cold then it's the diverter valve, either to replace or if it is one which has a internal diaphragm-replace that
Nov 25, 2009 | Water Heaters
The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
Oct 10, 2009 | Whitehaus Kitchen Single Handle Faucet...
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
I have a tankles hot water heater. The problem is
this is a problem they didn;t tell any one about, there is a min of 1 gpm that you have to run for it to sence for the unit to come on, if not the unit will not detect the water is even runnig there for will not come on,, as for the kit faucet, it might have a temp control and it may need to have a cartridge change, the water comming from the tankless is nothing like the old tank heater, the water only losses aprox 1 or 2 degree where a tank heater losses almost 5 or more because of the way the cold water is fed into the unit,, thats whay the sprayer works and the faucet doesn't ,, you have control on the sprayer unlike turning the faucet on,,
Jun 17, 2009 | RTO Chronomite S-90I 277v Instant-Flow SR...
Hot water out line seems to be pluged
make use our cold water feed that is going in to your tank is all the way open
Mar 04, 2009 | Water Heaters
The clothes in the washer dryer at the end of the wash are really hot and therefore start to shrink the dryer button is not on and the wash is on a 30 degree heat can you help?
If you have washer set for a warm rinse and the cold water inlet screen is restricted you will get too much hot water. Another thing I have seen is if another near by faucet has a sprayer on it and the sprayer is off, but the hot and cold valves supplying the sprayer are on, the hot water can feed back through that faucet and give you an increased rinse water temp in your washer. Also, make sure hot and cold hoses are attached to the proper side of the inlet valve.
Sep 02, 2008 | Whirlpool Washing Machines
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
377 people viewed this question
Top Price Pfister Plumbing Experts
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
