Question about Dual Electronics CECT P168 Cellular Phone
Can I set up i9 to Wi-Fi internet? Richard - Dual Electronics CECT P168 Cellular Phone
    Problem Solver:
  • 10 Answers
Simple answer... No
Posted on Jun 28, 2009
My M800 won't cannot detect any wifi or network and i can't get online
try to connect via lan cable.if u get online then look for wifi switch !
Apr 09, 2015 | Computers & Internet
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
Why wont my wi-fi 4g advanced , setup
Richard we all need more information to work with
4g are you referring to mobile data on a mobile phone network. Richard ?
Setup what are you trying to setup a USB Dongle or are you connecting via a mobile phone ?
Or are you using a 4g mobile data wi fi modem hooked into each device via wi fi ?
what operating system is on your laptop ?
Dec 27, 2014 | Computers & Internet
I need internet
You have to own a net zero to access it.Yet any computer is Wi-Fi and can be set to access any Wi-Fi as long as you're close enough to do so.Walls make it a bit harder to access Wi-Fi or boosters.Get your computer set up for Wi-Fi accessability and you can get internet at McDonalds.Or coffee shops like StarBucks.
Apr 15, 2014 | Computers & Internet
My ZTE v9 tablet phone will not connect to the Internet
you can access the Internet through the mobile network or via Wi-Fi.Your mobile network settings are pre-configured by your serviceprovider and there is no need to change any settings. Wi-Fi Wi-Fi provides wireless Internet access over distances of up to 100meters.1. Tap Home > Settings > Wireless & networks .2. Select the Wi-Fi check box to turn Wi-Fi on
Dec 02, 2012 | Cell Phones
My new zte v9 wont connect to the Internet
Dec 02, 2012 | ZTE V9 Smartpad Android Internet Tablet
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
Samsung sch-i730 cant access wi-fi
To acces the internet have you tried:
START
PROGRAMS
INTERNET EXPLORER
For Wi-Fi:
START
SETTINGS
Wi-Fi
Tap red bar to switch from Wi-Fi Disable to Wi-Fi Enabled.
Apr 10, 2009 | Samsung SCH-i730 Pocket PC
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Dual Electronics CECT P168 Cellular Phone Logo
829 people viewed this question
Top Dual Cell Phones Experts
William Alequin
270rexton
270rexton
iphone service
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
