Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Engine smokes and looses power
I have a 22HP briggs V twin vanguard engine that is running very rough. When cutting grass what usually was no issue now boggs down the mower. Am seeing some white smoke. Pulled the spark plug, they were very black. Replaced with new ones and properly gapped. Ran OK for a short time (several hours). Then it ran rough again. Check the plugs, again very balck. Cleaned the plugs, same thing. what else to check. I am not afraid to tear it apart, but have no manual on that.
Thank you,
mike
    President:
  • 1,723 Answers
Check the air filter, replace.
Posted on Jun 27, 2009
Craftsman lawn tractor 42in w/briggs 22hp -low power up hill and cutting
white smoke is more than likely a water issue. Oil usually has a bluish tinge to it but is some cases, it could be white. Drain the gas a fill with fresh to try and eliminate the possibility of water in the gas. Watch the oil level to see if it changes after using the mower. it may take a few times but if it is burning oil, the spark plug will look "wet" and oil soaked, with possible black soot type build up.
Aug 13, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
24horse vtwin runs good at half throttle seems to lack power.turn on the mower deck and sometimes it runs ok but will not mow normal lenth grass not much power.if i turn the throttle up wide open it will...
Sounds like you're getting enough fuel (black smoke) Could be running on only one cylinder. Either stuck valve or loose valve adjustment or one bad magneto. You could try starting with one spark plug disconnected. If it doesn't start, reconnect that one and disconnect the other. IF it runs like it was, then you're running only one cylinder, and go to work on finding out why.
Aug 04, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
27 horse power briggs on poulan pro. It smokes,
Very likely, the piston rings are badly worn or stuck. There may even be a small hole in a piston. In any case, you will need a major tear-down to repair this one. This is usually caused by lax oil-changes. It might be better to purchase a replacement engine than try to fix everything that could be wrong with the present unit if you take into account parts and labor. Hope this helps!
May 24, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
22hp Briggs problem. Loading up, runs
Try checking the prefilter on your air filter. I had a similer problem and mine prefilter was completly covered in dirt. I changed the air filter and it solved my problem. Also make sure the air intakes are not partially clogged with dirt or other stuff.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
1,030 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Bill Boyd
Daryl Gleaton
obsteiner
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
