Question about LG WM2277H Stainless Steel Front Load Washer
Clothes do not smell fresh and have a distinct smelly odor after washing. I think it may be the water filter or something to do with the water coming into the washing machine. Need help.
  • 31 Answers
Put your weasher on with white viniger on its own. also take your soap draw out and make sure that is free from powder as some times there is a back up of powder going in to the drum
Posted on Jun 26, 2009
Used wrong water filter. Now that we replaced with correct filter, there is a horrible odor in the refrigerator.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
Putting in the wrong water filter will not effect the smell in your refrigerator. At times the granules in a water filter will break down and get into your water dispenser and ice cube tray. This should not create a bad smell, just cloudy water.
Your plastic liner in your refrigerator has pores and holds odor. You have something in your fresh food section or freezer that is spoiled. Your fresh food section receives cooling air from your freezer. If you have a spoiled product in your freezer you will not smell it because it is frozen. But, as the cooling air goes into your fresh food section and cools down you will smell it.
Find the bad product in your freezer and discard.
With a 50% solution of white vinegar and water wash the plastic liner.
Now you can put a tray of baking soda in your unit, until you purchase deodorizers based on temperature requirements, one especially designed for the freezer section and one for fresh food section. These deodorizer are about $12.00 each.
Try Lowe's and Home depot.
May 11, 2015 | Samsung RF31FMEDBSR Stainless Steel 31 cu....
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Clothes have a smell after washed and have tried using tide solution for front loading washing machines is there a cleanout in this model
The washer (Unless used) should not introduce any odors into the wash.
The likely culprit is your water. See about getting a sample of clear water and check to smell if the odor is present. If it is, filter it, and contact your water company.
If your washer is used, it is likely to have a filter that needs to be changed. There maybe debris in the filter contaminating the wash.
Sep 26, 2010 | Crosley CW5000 Front Load Washer
Clothes smell like body odor after washing. using tide ultra he2 detergent.
i had what sounds like a similar problem. i complained of our laundry smelling sour then finally like sour sewage and a flooded laundry room. i was told that when its not draining properly, it can create a siphon-effect and actually pull the dirty water back out of the drain lines-yuk! i hope this isnt true.
there was a baby sock stuck in the pump preventing it from draining properly. hope your problem can be remedied as easily.
as for the smelly clothes, i always add 1/2 cup white vinegar to each load. it does wonders for odors.
Aug 13, 2010 | Washing Machines
We have a Hotpoint washer model VBSR2080WOWW purchased 2001. Problem is that clothes often don't smell fresh at end of cycle. There is a musty or mildewy odor or sometimes they have body odor. Problem is...
you have too much body fat built up in the hoses and main barrel what you need to do is run it with pure hot water and put a dish washer cleaner fluid in the wash this will destroy all residue that has built up in your washer that is rotting as it sits.
good luck
Jul 01, 2010 | Washing Machines
Clothes are sour after wash
The odor is being transferred from your washing machine. The washer must be cleaned first or the clothing will be reinfected upon washing.
The problem area is always just above the normal waterline where suds and soiled water splash up and don't get rinsed out.
To clean your washer add 1 cap of smelly washer cleaner to a full load of laundry in a hot cycle. The added bulk of the laundry will raise the water level to include the "splash area". Intermittent pausing to soak is a good tip for more extreme problems.
Jul 06, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Odors
Unfortunately this is a common issue with low water consumption front loading washers.
Fortunately there is a pretty easy fix. There are products that work great in cleaning out the hidden area that the odors come from. I have put some information on this together, follow the link below to see how to resolve, let me know if is helpful.
Smelly Washer
May 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Odor
I think that you may need to clean out the water pump filter as this clogs up with smelly sludge you may also find a few coins for your trouble....
Jan 03, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore front load HE washer odor
How old is your machine? Mine is 5 years old, and I just started to get a "sewage" smell in my laundry room this weekend. I disconnected the water return to the sewer line and discovered lots of gunk in the hose, and the connector to the machine was completely dark green. I'm going to replace the hose, and trying to figure out if there is some sort of filter.
We only use He detergents too, so I guess this is something that just happens over time.
Oct 09, 2008 | Kenmore Elite 45986 Front Load Washer
Smelly washer
I found out the hard way. The GE WCVH6260 fron loading washing machine has a terrible design flaw. There is a 'filter' that sits right in front of the discharge pump. This filter clogs with lint, coins, hair, dollar bills ... etc about every 3-4 months. When it 'clogs', the pump cannot '****' the dirty water through the gunk. As a result, you have nasty, stale water (forever) preventing dirty water from being flushed. What's worse is that since the dirty water cannot leave, you wind up washing/rinsing your 'clean' clothes with dirty water. It is easy to fix.
When looking at the front of your washing machine, there is a rectangular panel at the bottom. Remove the 3 screws (left, right and center) and pull down on the panel. It slides off easy. Right in front of you is a 3" cap. MAKE SURE TO HAVE A LARGE POT TO CATCH THE SLOP BEFORE YOU LOOSEN THE CAP. Remove the cap and pull out. (I took out 'gunk' the size of a tube of racket balls (coins, hair, dollar bills .. etc). You will also see/smell what I mean by 'dirty water'
GE is a bunch of idiots. We have only had our machine 12 months. This is obviously 'regular maintenance' kind of stuff (kind of like periodically cleaning the lint filter on the washing machine) and GE doesn't even make the 3" cap accessible from the outside. I checked the manual and these problems are not even FAQ's in the manual:
* machine 'pauses' between every cycle (push start to continue)
* clothes smell musty
* water doesn't drain
* cycles (consistently) take longer than timer says
* clothes still soaking wet even after spin cycle ... etc)
Dec 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
LG WM2277H Stainless Steel Front Load Washer Logo
175 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
