Question about Logitech X-530 Computer Speakers
Speaker creaking - Logitech X-530 Computer Speakers
    Problem Solver:
  • 6 Answers
Is it the cracking sound that you hear when the system is left on with no or little input? I have the same problem occasionly, if you leave them on with no input it can happen, turn them up a bit, not mega loud but up. i dont know why but this helps me, stops them for a couple weeks and each time it happens just do it again.
Posted on Jul 02, 2009
Speaker, front creaked
What exactly do you mean? The grill is bent? The cap on the woofer is pushed in?
Jan 21, 2015 | Philips HTS3544/37 Theater System
Hear a creaking noise under the dash on the driver side, it goes away if i accelerate or hit the brakes. it seems to be vacume related. could it possibly be the brake booster. It makes the noise constantly...
The exact nature of the creaking is important, and you have not provided enough info to narrow down the problem. The only "creaking" noise I have ever heard like that was coming from the front wheel. If it is going "creak -creak-creak" and changes as the car changes speed, I would check that.
Mar 04, 2018 | Buick Century Cars & Trucks
Ford ka creaking on drivers side when driving over bumps in road or turning
Is this a suspension creak, or a door creak?
Components which you haven't had changed are:
bottom suspension arms
Anti roll bar links
Also lubricate your door lock mechanism, hinges and window rubbers as these can cause creaks from time to time.
Nov 13, 2012 | Cars & Trucks
Where are the insert points for front end greasing? hubby has greased it but it is still creaking a squeking pretty bad. he missed some maybe?
creaking usually comes from struts or from bushings on the A-arms. Get struts replaced recently? Could be the isolators (rubber between spring purch and springs) deteriorated. These are usually the prob if it creaks when you turn the wheel. If it creaks when your push on the car up and down - its a bushing. These dry up and crack and/or creak when old.
Jan 23, 2011 | 1999 Lincoln Town Car
On my celestion ditton 150's there a gritty creaking when i gently press in the cone of the mid range. why is this, and can i resolve it? maybe remove the cone and clean it? thankyou.
Hi Lewsville,
Assuming after more than 6 months you still have the same problem...
The most likely explanation is that the voice coil is burnt out. This will definitely affect sound quality and will probably deteriorate over time. Cleaning won't fix this problem. You'll probably need to get the speakers re-coned by a speaker technician.
This link might be helpful: http://www.colomar.com/Shavano/recone.html
Cheers, Andreas
Sep 28, 2009 | Celestion 15i Speaker
Sleeve where filter goes in is creaked anyway to fix without replacing the sleeve. THANKS SO MUCH
I have been known to 'wire' up the skimmer filters to fix creaked skimmers.
Copper or Stainless wire
Jun 01, 2009 | Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual...
2000 Jeep Grand Cherokee Creaks over bumps
Just start at the front and lube every thing that has a lube fitting. Make sure that you lube all the drive lines. this should stop your creaks.
Apr 08, 2009 | 2000 Jeep Grand Cherokee
A creaking noise when the freezer is opened & then closed
In some freezers they build up excessive vacuum which pulls the plastic housing away from the internal polyurethane insulation, hence the creaking sound. You can make a vacuum breaker by attaching a small stick or similar to the bottom of the door gasket, this will break the vacuum without losing temperature.
Mar 12, 2009 | Refrigerators
Groaning frig
BFULLAWAY had the answer, I believe. My ice maker does the same thing, groaning and creaking for a few seconds, stopping briefly, then starts creaking again. This is due to ice stuck inside and it will make no ice as a result. Usually I see a piece of ice protruding and knock it out. Happened recently, but I saw no ice. Took a cup of hot tap water (not boiling) and poured it into the compartments where cubes form. (Made sure ice tray was in place to catch water.) I banged on the side and a misshapened cube fell out. Creaking/groaning stopped and unit began to function normally.
Apr 28, 2007 | Jenn-Air JFC2089HE French Door...
Logitech X-530 Computer Speakers Logo
70 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
