Question about Panasonic Televison & Video
Replace lamp and lamp light continues to blink and will not come on. lamp is good but will not power up. fan is on so there is power. any suggestions?
    Problem Solver:
  • 8 Answers
Usually if the lamp light starts blinking and it will not fire up after the lamp is installed then that means that you still have the lamp door of and the toggle switch that detects the lamp door being off is activated and so the tv is in failsafe mode and is not turning on to protect you. If you know that you have the lamp door back on and the switch is pushed back into place as it is supposed to be then the issue is most likely your ballast. The ballast can appear to be the same symptoms as the lamp. If the lamp itself was not damaged or broken then its possible the lamp was fine all along and the ballast is bad. The ballast is the board the connects to the lamp and charges up the high voltage to fire up the lamp. If it is damaged in some way then the lamp will not fire. Just as a precaution you can test the wire connected into the ballast from the power supply board and make sure you are getting voltage. If you are getting voltage and the lamp is good and the lamp door toggle switch is not activated or the lamp temp board wire is not unplugged then you definitely have a ballast problem. Those are the only components that can cause the lamp to fire. The lamp temp board is a little board on top of the lamp housing that just has 1 small wire connected to it that is a thermometer. If that is unplugged the lamp will also not fire. So, requirements for fire lamp:
1. Power from power supply board to ballast
2. Ballast converting power out to lamp
3. Lamp door switch must be suppressed
4. Lamp temp board must be plugged in and functioning.
Posted on Jun 26, 2009
Epson 84+ green light blinks no light
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
May 21, 2012 | Epson Corporati PROJECTOR, EPSON,...
I have an Infocus SP 7200 projector that will turn on, fans run and the color wheel spins and the projection lamp blinks briefly on for a second but then straight away the color wheel winds down and the...
Color Wheel could cause this, it must spin exactly 9,000 rpm per second ,but so can having a bad ballast board it is what powers Lamp on, If you still have the old Lamp and your sure the Lamp was Bad then reinstall old lamp and see if their is an ark coming from Spark Gap on the Ballast Board,
If you see an ark then Ballast is OK.Heres another thing watch the Lamp Fan if it is defective Lamp will not power on, If the Lamp Fan stops when Lamp trys to firer,then replace the lamp Fan.
Jun 29, 2011 | Televison & Video
My PT-50LC13's LAMP and TEMP light blinks 4 times and POWER light blinks 8 times continuously with 2 second intervals. I replace TY-LA1000 and FBL12G12L2CS Fan, but didn't fix the problem. Can anyone tell...
Listen carefully to the TV after the relays click. If there is a mechanical ticking or snapping noise after power On, replace the lamp because HV is present (causing the ticking). If there is no ticking sound, replace the ballast. You can confirm this by using the LED blinking pattern to localize the problem. refer to Service Manual or technical guide on the panasonic website for more help diagnosing LED patterns
May 01, 2011 | Televison & Video
InFocus ScreenPlay 4805 no projection. Unit powers on and green light blinks, but no light and no fan, eventually red light blinks continuously about 2 seconds between blinks. When the green light is...
the high-pitched sound is the colorwheel trying to spin up to speed. that may need to be replaced. check the inside of the lamp for bulges, black spots, fogging or flaking. if it has any of those, replace the lamp. you can get parts from an infocus service center or send it to them for repair. either way, try www.avsolutionsny.com they're really good. if you want to replace it yourself, there is a detailed step-by-step on my "tips" area. it's the same as the infocus x1, x2, x3 and sp4805. click on my picture and scroll down to tips. good luck!
Feb 01, 2010 | InFocus ScreenPlay 4805 Multimedia...
The power light continues to blink and will not go solid.
what is the projector issue? is the lamp not lighting? are the fans running? did you just replace the lamp? is the led red or green? need more info.
Dec 29, 2009 | Sharp XR-30S Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
Power light blinking and housing for lamp screws broken
I bet the area around the lamp shows signs of warping and/or cracking too? This is a VERY common issue as the fan that sits above the lamp gets clogged with dirt which allows the lamp to over heat which decreases the lamp life as well as distort the plastic casing around the lamp. The fix is a thermal fuse kit and a new fan and of course a good cleaning of the other fans in these TV's. This should be performed by a service technician.
Aug 31, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Blinking lights and pwer down
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jul 03, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Televison & Video Logo
509 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
