Problem with my sagem pvr 64160t
What is wrong with my sagem?? When i start it the panel says 8888 then after a few seconds shifts to er09. When i try to press a button on the remote it changes to er01. Im out of warenty. I have tried whith another hard drive exactly the same thing!!! Can anyone help me????
  • 74 Answers
You may see the booklet!!!
Posted on Aug 10, 2010
  • 4 Answers
Powering on a Sagem 64160t after disconnecting the HDD will produce the problem that you are experiencing. Sagem build quality can be poor. After opening the case, carefully check the data and power connections to the HDD for joints that lack solder or that haven't been properly seated. If the connections are good then the problem lies with the HDD, which may have failed. Unfortunately, DIY Sagem HDD replacement can be problematic.
Posted on Sep 10, 2009
Shows ER07 ER09 ER 01 Scrolls through 01 etc. and eventually shows ER09 SAGEM Model DVR 6200T/6400T
I had a very similar problem. On initially starting up it showed Pb03 then would cycle between er07 er09, er01 and counting up 00,01 up to 19 or so.
Nothing I did fixed it including turning it off for a long period and back on without the aerial.
Eventually I fixed it by pulling out the power cable while it was counting up and then on powering back up it started to initialise correctly. No idea what the problem was and why this fixed it but it might be worth a go. It didn't involve losing any recordings.
Jul 26, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
My box sagem pvr 6240 stop suddenly and started to flashing er09, l turned off for 2 hours and when l restart it shows pb03 and change and keeping flashing er09. I have manipulated the buttons, pushing...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Sep 07, 2017 | Sagem PVR 6280 Freeview DTV Receiver /...
Er09 and Er07 black screened
Turn off the unit for 15 mins.
Turn back on with eveything connected except the antenna.
You will get an er 09 on the display.
Press OK on the remote.
With a bit of luck the box will reboot into standby.
Connect antenna and see how you get on.
Jan 07, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
Hi :-) I also have P603 / Er09 / Er07 / 00-- Error messages, even after being unplugged overnight. Upon power application the unit clicks quite loudly 10 times in a row, then repeats this 4 times, before...
contact sagem 0835 0900316 technical support helpline you will need serial number of your box and the model a new power adapter was all I needed and can now watch all the programmes i had on the disc and thought i had lost
helen april 2010
Oct 11, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
DVR6280GL-UK. Flashes er07 and er09 after attempt to reset. What do I do to fix it?
The Sagem PVR 6280 is specifically listed as a model which will have problems with the retune.
See the address below for a chart of affected models, but the official advice is that you must contact Sagem directly on 0845 0900 316 for either an over the air update or an update DVD depending upon the manufacturer.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
Sorry I can't provide you with a definite solution but I hope that I've at least reassured you that it's not something which you have or haven't done!
Please return the favour by rating my answer.
Oct 02, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Sagem 6200T
The Sagem PVR 6280 is specifically listed as a model which will have problems with the retune. Although the Sagem PVR 6200 and 6200t are not specifically listed as problem models they are very closely related to the 6280/6240 models and share most of the same firmware and software.
See the address below for a chart of affected models, you'll need to contact Sagem directly on 0845 0900 316 for either an over the air update or an update DVD depending upon the manufacturer.
Sorry I can't provide you with a definite solution but it's very likely that your model is one of those which only Sagem can sort out.
Sep 24, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Error code 09
Er00 - The software that was available for upgrading was of an older or of the same version as the one already in the digital-box.
Er01, Er02 -The upgrade failed. Some information was missed out.
Er03 - The internal memory is not large enough to receive the upgrade.
Er04 - The signal was disturbed during the upgrade.
Er05 - Wrong type of data was received during upgrade.
Er06 - Not used.
Er07 - Access problem in back-up memory (EEPROM).
Er08 - Access problem in video memory.
Er09 - Can not find any data to do an upgrade.
Er10 - Poor or no cable-TV signal.
Er11,12 - Not used.
Er13 - Unauthorised data signals received by the digital-box.
Er14 - Faulty data signals received by the digital-box.
Pb01 - A problem in the ROM memory is detected.
Pb02 - Memory size is too small.
Pb03 - A problem occurred during start up (initialisation
problem).
Pb04 - Internal communication failure.
PbF9 - Hardware error identified during start-up
From elsewhere on the web:
1. Turn off the unit for 15 minutes to cause a full reset.
2. Turn on the PVR with everything attached except the antenna input.
3. You will get an Er09 on the display. On my PVR there was no output on the TV screen whatsoever (totally black screen).
4. Press 'OK' on the remote (confusing as there is no clue that this is what you should be doing, though Sagem support thought that the PVR should prompt you.
5. The box reboots in standby mode."
Good Luck...
I also see some mention that if the above procedure doesn't work, try pressing "Menu" twice to see if that clears error 09.
Mar 05, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Sagem PVR 62160T UK
I left it plugged in while watching a DVD for about 90 min (as Sagem and DVD are all connected up with the TV). Afterwards I noticed the Sagem was now displaying Er09. I tried pressing the green button on remote control to activate the Sagem and hey presto everything came back on (with a message saying that the download was now complete). All back to normal now. I think the 00 and flashing dashes just meant that the Sagem was downloading and that this took longer than the specified ' few minutes'. Not sure what the 'improved DTV' was though - I can't see the difference!
Jul 16, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Televison & Video Logo
548 people viewed this question
Top Televison & Video Experts
