Question about Bosch 1194AVSR 1/2" Vsr Hammerdrill
Chuck on Bosch 1194 vsr drill is rusted... how to remove?
How do I remove the entire chuck? is it attached with normal threads or left hand threads? it is pretty rusted in place. There is a screw on some of the expanded drawings (but not on all of them)... that may hold the chuck on, but why then would the shaft be designed for using a wrench?
thanks!
  • 2,176 Answers
You are half right. The screw that you see is a chuck retaining screw (LH thread) to keep the chuck from loosening up when in reverse. What you need to do is if you have one remove it first and then find a bent handle allen wrench about the size of the chuck capacity, lock the shorter end in the jaws and then position the wrench at about a 30 deg angle and put the chuck on a block of wood or bench and take a hammer and hit it counter clockwise. If you have a wrench small enough to lock onto the spindle use it and brace it on the bench. If this tool has a high and low setting use the low and if clutch equipped the drill only. Let me know if you need more help
Posted on Jun 27, 2009
  • 4 Answers
Another Bosch drill, an old CBS 550-R, but same problem. As above, I hit the Allen wrench, while holding shaft with a 17mm wrench ground down to fit the 3/16th gap between chuck n drill head. Nothing gave! After clouting it several times with no gain, I lay the drill on a folded towel upon the kitchen floor, put right foot upon drill, put all of my 180 pounds on the 17mm wrench and right handed belted the allen wrench with a sguare faced four pound hammer against the clock and the flamer freed off. It took one hell of a wallop before freeing off. Best of luck to anyone with an old well seized chuck.
Posted on Sep 23, 2012
How to remove keyless chuck
open the chuck jaws right up
down the center of the chuck you will see either a philips screw head or a hex head for allen key
hold the shaft at the base of the chuck to stop it from turning and undo the screw in the chuck in a right hand direction ( it is a left hand thread) when you have that out , still holding the shaft turn the chuck in the left hand direction ( normal thread ) and screw the chuck off
to assist in undoing the chuck do it up so that the jaws come out a bit
place something between the 3 jaws to act as a lever or use an allen key in the chuck done it tight and use that as a lever to undo the chuck
the secret is the lh thread screw in side the chuck which stops it from undoing when the drill is in reverse
Nov 17, 2015 | Bosch 18V Brute Tough Drill with Blue Core...
Psb18li-2 chuck removal
There should be a screw inside the center of the chuck. It could be a left hand thread. Remove the screw then pull the chuck off.
Mar 11, 2015 | Bosch Drills
We need to replace the chuck on our Bosch corded drill 1005VSR. We need detailed instructions on how to remove the chuck . Also, how can we order a new chuck?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench 1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 15, 2011 | Bosch Drills
Need to replace the chuck on a Bosch 1194 VSR Model number 0 601 194 739
open the jaws of the chuck up all the way. There is a retaining screw at the bottom ( under where the drill bit would go). this screw is reverse thread. once the screw is out, get a 3/8 inch allen wrench. chuck the short end into the drill chuck. set the drill on a workbench with the chuck hanging off the edge a bit. Hit down on the allen wrench with a hammer ( counter clockwise) and the chuck will unscrew normal thread.
Oct 21, 2010 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
Craftsman Model #315.271690 3/8 Professional Electric Drill (corded). What are the specifications (dia, threads per inch, etc.) of the left hand thread machine screw that holds the chuck on. The Sears...
How do you remove the chuck from a Craftsman Model #315.11441 3/8 vsr corded drill? Am trying to remove the chuck but I believe there is some type of a set screw or locking mechanism that needs to be undone. I can see a slotted screw head in the chuck Looking straight down on it but it is very tight and I don't want to break it or a screwdriver forcing it. Thanks for input. Bob
Sep 06, 2010 | Craftsman Drills
How do I replace the chuck on a bosch 1199vsr?
If there is a chuck bolt in the center (where the bit goes) remove it (left hand thread). The chuck is threaded onto the splindle(right hand thread). On some of those drills they have a small hole in the housing that lines up with a hole in the spindle. Put a pin punch in to lock the shaft so you can unthread the chuck. If you clamp a 3/8" allen wrench in the chuck it acts as a good handle. If there are no holes to lock the chuck, if you lay the drill on a bench and give the allen wrench a sharp blow with a rubber mallet it will unthread the chuck. If the chuck is damaged and will not hold an allen key you will have to cut the spindle off and replace the chuck and spindle.
Hope that helps
Jan 27, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Need a chuck for a 1/2
Go to DeWaltService net.com and look up your model and type number. Inside the chuck is a left-handed screw. torx (star) T20. When you get it out, take an allen wrench and (if you can tighten it up at all, tighten the **** out of it). If not, find an allen wrench, a tiny bit smaller than the space allowed. Now, get a nice big hammer. The chuck is right handed thread. And knock it, spinning the chuck off the spindle. May take a few whacks. Use the edge of a workbench to keep it stationery if need be. Please rate me
Jun 16, 2009 | Dewalt 18 Volt Compact Drill Kit
I need to remove the chuck on my Bosch 33618 Brute cordless drill. How do I do it?
You must remove the inner chuck retaining bolt first, it is a torx screw and is left hand thread. once you have this screw out, get yourself a 1/2" allen key (the L kind). Chuck the short end in the chuck to grip it, use a mallet to hit on the long end (this will unthread the chuck). The spindle thread is regular Right hand thread. It may take a few good hits to knock it loose but it will come off.
Mar 31, 2009 | Bosch 33618 - 2G Factory - Reconditioned...
Hi Seadog--can I download a manual for a Bosch 1194 svr hammer drill on your website?
Go to the BoschTools website and look under service and parts. You can download drawings there.
Jan 31, 2009 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
Drill chuck removal
The screw should be left hand thread and the chuck is normal thread. The 'workshop' way to remove the chuck is to remove the screw (done). If the jaws are still working then clamp a sturdy allen key in it and whack it against a workbench to unscrew the chuck. If holding the drill in the normal position you would stand with the workbench to your left and whack it down on that. If the jaws aren't working then you can grip the body in a vice and use large pipe grips or stiltsons on the chuck. Also check to see if the chuck spindle will accept a thin spanner to hold it, as this is a slightly more caring way to brace the spindle. Then you can can hold the spanner in the vice and use the allen key in the chuck and unscrew it that way.
Oct 22, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Bosch 1194AVSR 1/2" Vsr Hammerdrill  Logo
1,463 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
