Question about Arris SURFboard SB5120 Modem
Im having problems getting my modem to get online. The light wont come on. All but the online light come on. The online light blinks then all the lights go off except the power light, and the receive light blinks,becomes steady,then the send light blinks,becomes steady,then the online blinks and blinks. then the process starts all over again. 3 steady lights ,1 blinking light.
    Problem Solver:
  • 17 Answers
Re: Im having problems getting my modem to get online....
Your modem is not synching. It could be a number of possibilities, and you're going to have to do some troubleshooting to narrow it down.
  • Verify that your AC, Cat 5, & ethernet cables are connected securly
  • Verify that your modem is not in "standby" mode
  • Power cycle your modem
  • Try a different cable outlet
  • Call your ISP to make sure your modem is provisioned and your service is set up for cable internet.
Posted on Nov 09, 2007
0 characters
3 Points
Can't Connect To Internet
This has to be set up with a cable connected to it for the first time. Should be an install disk with this as well but if not you will have to get online somewhere and download driver.
Apr 13, 2014 | RCA Modems
Arris TM502G is cutting out when d/l heavy bandwidth.
Three things in the system. Modem, router, computer/xbox. You changed the router and problem still exists. The computer/xbox is calling for the data but the modem is stopping it even though your provider doesn't see it stop. Change the modem. Borrow one if you can but I suspect it is going glitchy.
Aug 25, 2012 | Arris Touchstone Telephony Cable Modem...
Computer tells me i have no internet connection but im online
this sounds like the internet service is available because the internet light does come on but it sounds like the password is incorrect. i suggest you contact your ISP to confirm you access is ok
Jul 01, 2009 | Efficient Networks SpeedStream 5100 Modem
Cant hook up xbox 360 to internet
does this help it sounds like you are puting your cable in to the 360 and the modem you wont have a internet ligth on untill you try to connect the 360 to go live you must reset the modem
Jan 23, 2009 | Zoom X6 (5590) DSL Modem (55900003)
I have a macbook that I cant get to connect to my 2wire modem correctly
Make sure that the airport is on. Connect to your modem & type in the wireless password.
If still having problem joining the network, delete the keychain but make sure you only delete the keychain for 2wire by going to utilities then keychain access.
Oct 08, 2008 | 2wire (1000-000057-000) Modem
Installing My New Motorola dsl modem
-- what is the model and brand of your modem?
-- who is your internet service provider?
-- is your account activated?
-- do you have a username and password from your ISP?
-- have you tried changing cables? what about the phone port?
May 08, 2008 | Modems
Modem compatibility problem
bcm is mostlikely broadcom check the pack for the manufactures name then go to their for download
May 07, 2008 | Modems
2wire modem connectivity
According to me you must reconfigure the modem.Becoz sometime modems are disruppted by viruses which cause funtionless of modem.If u have backup files of it you can try tis process.
Dec 13, 2007 | Siemens SS5100 Modem
What light does not come on? There is the power light and several other lights. Is there also an on/off switch on the modem itself?
Mar 19, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Arris SURFboard SB5120 Modem Logo
1,513 people viewed this question
Top Arris Modems Experts
Sudeep Chatterjee
Sudeep Chatterjee
Terry Allen
Terry Allen
Are you an Arris Modem Expert? Answer questions, earn points and help others
