Question about Panasonic KX-FL511 Plain Paper Laser Fax
I actually have a Panasonic KX-FL501, not the 511. However, I think they are very similar. The problem is the paper won't feed reliably anymore. I suspect the rollers are degraded and need to be replaced. Is there a source for refurb parts?
    Genius:
  • 1,689 Answers
Here is the part for you.
Genuine Panasonic KXFL511 Doc Feeder Part
http://www.precisionroller.com/doc-feeder-parts-for-panasonic-kxfl511/details_34724.html
Posted on Jun 26, 2009
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
Document won't feed
Paper Pick up Rollers get dirty or worn out with the passage of time. Hence, require cleaning or replacement if worn out. In case you find them dirty use a soft, dry, lint free cloth to clean the rollers. Dont use chemicals as they may damage the rubber and plastic. However, if needed, you can use damp cloth or some cleaning liquid such as mild detergent of glass cleaner to damp the cloth. As you have posted your question under Panasonic KX-FL511 is would highlight the steps for it. Im Using a similar model KX-FL612
After lifting the top cover, you have to pull down the under part of it down to locate the rollers
Lift the top Cover, Locate the roller and clean them..
Hope it helps! Good Luck!
CreativeTECH
Dec 01, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
Feeder scanner stop after 1cm scan/fax
You need to clean the rollers inside the feed section, use an alcohol wipe.. or something like methylated spirits and a rag..
Oct 16, 2009 | Panasonic KX-FL611 Plain Paper Laser Fax
The result of paper not clear using KX-FL512 eventough i replaced the tonner & catrige
The message might be refering to the transmit area not the recieve area. Open your document path and make certain that there's nothing in the feed path.
It's also possible that a piece of paper is actually stuck in the paper path near the fuser area. This may or may not be accessable in your particular unit
Sep 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Is there laser fax model 612? Its the same as 611 or not?
Yes those Panasonic models are the same just the KX-FL 612 is different from KX-FL 611 in some specifications like as example:
611 prints maximum 14 pages per minute and 612 prints 16 pages per minute. The document feeder on 611 can feed maximum 20 pages while 612 can feed 30 pages and some other compare stuff like those.
Mainly KX-FL 612 is improved version of KX-FL 611
Jul 11, 2009 | Panasonic KX-FL611 Plain Paper Laser Fax
How do you adjust paper feed on a panasonic kx-fl511fax/copier
One of two things is happening ok maybe three. If the machine thinks the size of the paper is not what u are using this could happen. Try:
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FL511%20Laser%20Fax%20Machine.pdf
For any adjustment you could make.
The second is the paper is getting picked up a little late. The machine knows it did not print the entire page and finishes the job. Try cleaning the pick op roller.
The third is the page being sent to you is to long. This would likely be from one location only. There machine could be slipping when scanning and "extending" the page it is trying to send.
Hope this helps
Mar 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Kx-fl511 wont pick up paper
try cleaning the paper pick up rollers with rubbing alcohol, use a cloth rag and the alcohol, try to rotate the rollers so that you can clean all the way around
Feb 26, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Re: Panasonic KX-B530
it generally means you are out of thermal paper. or it is jammed and not feeding. Hope this helps.
Aug 16, 2007 | Panasonic Panaboard KX-B530 Graphic Tablet
Panasonic KX-FL511 Plain Paper Laser Fax Logo
62 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
