Question about LG Washing Machines
White foam ring? on underside of LG washer
Is this supposed to be removed or remain?
3 Suggested Answers
  • 44 Answers
SOURCE: no one seems to be able to answer this question
i would guess that it would have to be removed as it would prevent the barrel moving freely and would be causing it to vibrate the machine.
Posted on Jun 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: There is mold on the underside of the door ring.
It cannot be cleaned - it must be replaced.
The rubber absorbs the mold - and you cannot get rid of the smell.
This part is called a door bellow.
It will require disassembly of the machine to replace - and a professional service contractor is recommended.
Thanks for using Fixya - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Dec 30, 2009
Testimonial: "Very quick response. Professional advice and approach. Provided terminology to approach expert with. Thank you"
How do you take a 5k5m150 apart
Tap drip ring off, punch out pin through planetary. Remove back cover, unclip black wire and white wire from rear control board. Tip it upside down, remove pedestal. Undo 5 screws around where planetary came from, undo the remaining 4 screws on underside of gear case, pull the cases apart.
Mar 01, 2014 | KitchenAid K5SS Heavy Duty Commercial...
How do i split the case
Chrome drip ring off, knock pin out of planetary, remove planetary, back cover off, black wire and white wire off the control board (both on the same side at the bottom) undo 5 screws under planetary, undo 4 screws remaining in housing underside. Split cases.
Jan 18, 2014 | KitchenAid KSM150PS Artisan Series Stand...
My amana top load washer is foaming out of the discharge
sounds like you need to clean your washer , use white distilled vinegar about 2 cups on a heavy hot wash and if you are still foaming you can use vegetable oil to remove suds , repeat if needed
Feb 17, 2013 | Amana Washing Machines
I need help solving a matchstick puzzle. There are 9 equal squares, in a pyramid shape with 1 on top, 3 under that, and 5 under that. I'm supposed to remove 10 matchsticks and leave 4 equal squares. ...
Good Day!
here is the image where you can remain the 4 squares and removing 10 match sticks. Red sticks here are the ones to be removed.
If this helps, please give some ratings!
Thank you for asking Fixya.
Sep 16, 2011 | Puzzle Toys
Is the Whirlpool WTW5100VQ2 washing machine supposed to spin on high speen during the delicate cycle?
Yes, Hight speed spinning cycle just remove the last remain water in the cloths. GB...stewbison
Sep 14, 2011 | Washing Machines
I have a LG washing machine Model # WM2688H*M it has a slight leak that I traced to a small black hose. The hose is in the back of the machine that goes from the bottom of the drum to the top somewhere...
It's not likely the hose is leaking, but rather water is leaking from somewhere else and is running down the outside of that hose. Remove the washer top by taking out the two phillips head screws from the bottom of the plastic clips on the back side of the washer's top. Now, stand in front of the machine and use the palms of you hands to sharply push the top cover back about 2 inches, then lift the cover off. Look for the water leak. The most likely suspect is a water inlet valve.
Jan 01, 2011 | Washing Machines
I just pulled out my Kenmore built in dishwasher which was installed 4 years ago and see what looks like a blanket of sorts draped over the top and down the sides. Is this some kind of packing material...
The blanket you are referring to is not packaging material. This is an insulator blanket that not only keeps the underside of countertop and adjacent cabinets shielded from the heat of the dishwasher tub, but also provides a noise barrier. Without it, the dishwasher may genrate more noise, and you may feel more radiant heat given off when the dishwasher heats the water. This is supposed to remain in place and should not be removed.
Dec 23, 2010 | Dishwashers
Is my fan supposed to remain on after I turn off the car
The fan will stay on until the motor temperature reaches a low enough temp. This is to prevent damage. As long as it does not stay on for more than a few minutes it is normal
Jul 26, 2010 | 2008 Saturn Sky
Weber Q 120--propane leak when removing canister
i would say that might be faulty mine just screws together and unscrews nothing falls out
Apr 20, 2010 | Weber Baby Q Grill
There is mold on the underside of the door ring. Am unable to remove ring in order to clean it. Washer thus has a musty smell. How do I clean this?
Dec 30, 2009 | LG Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
