Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
Hard steering 4000 ford 1964
New bushings and bearing . manaul steerig
  • Anonymous Mar 21, 2014
    i have a 1964 ford 4000 the books say there is a strainer or filter in the right hand corner of the case with the tubes . i have the cover off and there is nothing there .where is the inlet to the hydro pump
  • 634 Answers
You can fine the parts at Salem tractor supply in Salem NY they specialize in old tractor parts
www.salemfarmsupply.com/
Posted on Jul 17, 2009
1964 Ford Ranchero, advice on repairing sloppy steering mounted gear change
If you look under the hood where the shifter linkage goes from the column to the transmission. You should have 3 rods, and at the ends of the rods should be bushings. Over time, these bushings wear out and disintegrate away. You should be able to purchase a kit to rebuild your shift linkage. Just make sure you label the rods location and orientation before you remove them. It can become quite a headache if you get them out of order.
Oct 15, 2015 | Ford Cars & Trucks
Eps light comes on after driving for about 20 secs installed new ecu still have same problem steerig gets hard
who diagnosed the ECU , its more than likely to be the Electric Motor for the power steering as it goes hard , did you get the OBD codes read ? sometimes just clearing the code will cure the issue ,
Oct 05, 2014 | 2003 Honda Civic
I have 1990 ford f150 & when I drive it is all over road ie sways etc hard to keep it on road
There are many reasons for this problem. Check the following: Tire size and inflation, tie-rods, wheels bearings, ball-joints, center link, pit-man arm, alignment, twin-beam bushings, broken spring, sticking brake caliper, worn or loose steering box, cracked frame, worn, loose, or defective steering column components. I hope this information helps, please let me know what it was, good luck.
Mar 18, 2014 | Cars & Trucks
GOT 2006 FORD E 350 VAN STEERIG COLUMN FROM JUNKYARD BUT WHY KEY WILL NOT TURN
Did you change locks on the steering column, and/or are you using the old lock? If you did not change the lock on the used column, then you have the wrong key. You should use the old lock mechanism with the new steering column, and then there is no need for new keys.
Otherwise you will probably have to get a locksmith to cut you a new set.
Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Jan 27, 2014 | Computers & Internet
Just put kingpin and bushings in on 3500hd chevy steering is so stiff you cant hardly drive it.is it possible we could have put knuckles on upside down or on the wrong side?
No, But you might have put the bearing in the wrong spot. Or did you have to drive the pins in the bushings? You have to hone the new bushings after you press them into the knuckles so that the new pins fit right.
Oct 13, 2010 | Chevrolet C3500 Cars & Trucks
My steering hangs when turning to the left and
it could be your steerig box.some of the f150 and ford bronco and F 250had the same prolbem
Nov 11, 2009 | 1996 Ford Econoline
Streeing Noise
Fluid new and clean.? Flush system and use correct fluid. Hard steering-- Bad steering rack or strut bearings/bushings on top of towers
Sep 28, 2009 | 2006 Mitsubishi Lancer
I have a ford f150 year is 2000 and just when pulling in my parking area the steering whell got very hard to turn.
possible that you are low on power steering fluid, are power steerig belt loose are broke, are pump is goig out.
Jan 30, 2009 | Ford E-150 Cars & Trucks
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
520 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
