Wow, no year, no country. (information ,can vary by those, vastly)
engines ,wow.
no less than 5 engines.
get the fSM on your car, and no need to ask this. ever.
or discover the REAL engine NAME and search for that with google
and pray you find it.
SOURCE: corsa head torque settings?
for 4ee1
cylinder head
stage 1: 40Nm
stage 2: 60° - 75°
stage 3: 60 - 75°
let me know if u need any more of those
take care
SOURCE: reversing light is not working on my corsa 2006
check bulb and a switch on transmission when you select reverse it activates reverse lights
SOURCE: how can you reset the
Service reset
Important note: Proceed exactly as follows; otherwise the reset system will go into the locked position and special tools are required to unlock it (Tech 2 tester).
1. Turn the ignition OFF.
2. Press and hold the reset button [1] (see the above picture).
3. After 3 seconds the "Distance till service" appears on the display, "InSP 0".
4. Press and hold the brake pedal.
5. Note: Ensure the button [1] is still pressed.
6. Turn the ignition ON.
7. The display shows: "InSP----".
8. After turning the ignition ON, wait for the service message to change and keep the reset button pressed for at least 3 seconds.
9. Release the brake pedal and reset button at the same time.
10. Wait for 10 seconds, until the display shows: "InSP XX,000 km".
11. The system is reset.
SOURCE: i need torque settings for the engine ie head bolts v6 engine 1
i am replacing the heads on a GMC 350 cu in engine. what is the final torque of the head bolts?
