Question about GE Spacemaker JVM1640SJ Microwave Oven
Broken glass in door, how to take door off of . do you have the service manual
  • 5,911 Answers
The door comes off by simply opening it all the way and lifting straight up at the hinges. On some models you may have to remove the upper grill over the door (if equipped). I hope this helps you. Let me know if you have further questions.
Posted on Jun 26, 2009
Door glass replacement for siemens microwave oven
I suggest calling service any work on a door needs a special detector after the repair to any door part. Only service techs carry these units.
Nov 02, 2015 | Siemens Microwave Ovens
Replace inner door glass in a Maytag CWE900 built-in oven?
There is a poor diagram on Searspartsdirect.com, but no instructions. A diagram might help.
Feb 18, 2015 | Maytag Microwave Ovens
GLASS HAS BROKEN - CAN I REPLACE IT WITHOUT BUYING A NEW DOOR
The service manual is here. It will help you with step-by-step disassembly, show you what parts are available, and give you part numbers.
You can order GE parts and accessories by part number from the Pros here.
Dec 02, 2013 | GE Advantium 120 - Knob For Sca1001hss01
Need to know correct size of microwave door glass for LG model MG-604w mine is broken after a fall, can I still use without glass?
NO, do not use the microwave with a broken door glass, this glass is specially protected to stop any dangerous microwave leakage, it is also something you cannot replace yourself, take it to a reputable service centre so that once the glass has been repaire the oven can be tested for safety purposes.
Sep 09, 2013 | LG Over-the-Range Microwave
Door handle broken away from microwave unit.
The door handle can easily be replaced. This is a common problem with microwave oven doors. You would think the manufacturer's would make them a bit more durable.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions about this repair, please let me know. I hope this helps you.
Jul 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can i replace a broken door handle?
Yes. This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jul 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
A broken handle on door&how to fix it
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions, or need assistance ordering parts, please let me know. Post back with your Model Number if you need parts assistance. I hope you find this information helpful.
May 13, 2009 | GE Microwave Ovens
Microwave door glass broken
Here is the web page and phone number
http://www.haierindia.com/#
They are in New Delhi
Call them for the part
Please leave feedback
Feb 13, 2009 | Haier MWG100214TW 1000 Watts Microwave...
Broken glass on full sized microwave door
Unfortunately, you would have to replace the complete door assembly, you can find a replacement door assembly for this model at this link:
LG LRM1230W Replacement Part Complete Door Assembly
Jan 07, 2009 | LG LRM1230W Microwave Oven
Microwave door
That would be the service manual. You could contact Kichenaid for that, but I doubt the manual's necessary just yet:
http://www.kitchenaid.com/custserv/service.jsp
You can find helpful exploded views of this model here: http://tinyurl.com/gv383
Unless you're replacing the entire door for some reason (what an expense!) then it's not recommended that you remove the door. If so, you'll have to carefully mark the hinges and the door to be sure you get it back in exact alignment. Otherwise, you'll have a chance of microwave leakage.
Instead, the door panels should be taken apart and then you can remove only the panels and parts that are needed.
In most cases, there is a choke cover on the inside surface that needs to be carefully pried apart, and that will allow access to the hidden screws, as the sample drawing shows.
Usually the exploded view is all that's needed, but if you nned more help, the service manual is the next step.
Nov 21, 2007 | KitchenAid KEMC377K Convection / Microwave...
GE Spacemaker JVM1640SJ Microwave Oven Logo
102 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
