Why does the screen stay black when camera is turned on?
When the camera is returned on the screen stays black, it will replay any photos on the card, the shutter button works, it will set the date, menu works, etc. the lens works.
Re: Why does the screen stay black when camera is turned...
Did you try to press the display button several times? Most of the time you can cycle through different views on the display, with different information during record mode. One is display off.
please check that your camera has a properly working Sd card. If the SD card is potentially damaged, then you would not be able to view the damaged contents on the camera. Please take a few test photos and see if the display photos returns. If not, then it might be time for a factory reset.
FREE INFORMATION REGARDING YOUR CAMERA FIRST
The Stylus Tough-3000 can be submerged up to 10 feet underwater and incorporates four preset underwater scene modes as well as the ability to capture HD movies underwater. It can also withstand a five-foot drop and can still perform when the temperature dips well below freezing (14 degrees Fahrenheit; -10 degrees Celsius) SOLUTION 1. Remove the SIM card , battery, and ensure that your camera is dry2. reinstall the sim, battery, and if the battery has not been charged or is known to be used, please replace for a new one. 3. Start up your Camera and attempt to take a photo now without using any of the video features. If your still not registering your photos, return for continued assistance.
That sounds like a sticky lens shutter. They usually have to be replaced, as they usually will need parts. When the camera is working look inside the lens and take a picture(with flash turned off). You should see a black shutter door clicking shut in the lens. When the camera acts up, look inside the lens again. If the door is staying shut full time, that is your problem.
So the lens opens, But screen stays dark - can you see any shadow images or is it totally dark? Have you checked that images are in the card. Any way there is not repair option just replace it.
a penlight shined into zoomed back lens - shows
if iris is open ( ccd looks like a small xmas
tree scene , deep in center ) : if iris is
stuck closed , a thorough lens cleaning should
restore camera video - if iris is open , the
ccd may be or already has failed ;
