Question about Maytag EPIC MFW9700S Front Load Washer
EPICZ Maytag washer says F 21 - Maytag EPIC MFW9700S Front Load Washer
I SO have a solution to this problem. My family has owned this washer for about two years and it has had three F21s. Now I don't know if all F21s are the same, but this one worked.
First, take off the bottom front panel by removing the three 1/4" machine screws. The culprit is toward the right front of the washing machine. First I unscrewed the big "thing" and revealed the filter! What a treasure! We found all kinds of things.
Next the pump, just to the right of the filter, needs to be emptied. Disconnect the power to the water pump by unclipping the black wire on the far right. I removed the whole assembly after unclipping the wires and had the filter and pump sitting in my lap. Separate the pump from the filter body and viola, what a disgusting mess. I pulled out the fan blades (pull hard, it's a magnet afterall) to reveal that our pump was impacted with a black nasty sludge that looked like it came from a septic tank. Anyway, I cleaned the water filter, put both parts back together, installed the body, clipped the power back in! This took about 20 minutes and cost -$0-! It worked immediately. I searched for the part online (W10130913 -only $66) and will order a replacement part to install myself. SWEET!
Posted on Aug 21, 2010
  • 1 more comment
  • thoette Oct 28, 2010
    How the Hell did you figure this out??!! What a genius.~
  • kan-green Jan 05, 2011
    Go to my blog for pics of this fix. Kan-green.blogspot.com
  • 4yasun Jan 13, 2012
    Thanks soooooo. Much we had this "repaired" 1 time already.thank god it was still under warranty.they told us it was the filter...but after bringing it home..took bought a week..and same thing...I think they only cleaned out the bbig white thing...needless to say I followed ur insrucitons and made sure I disasembled it properly. Costs nothing and I didn't have to wait a week on repair man.
I also did this today and it fixed my issues. My pump motor had a rubber band around it.
Posted on Oct 30, 2011
Maytag fault codes f-28
Locate your Maytag dealer they have the proper tools of the job don't try to do it your self.
Aug 01, 2014 | Maytag EPICz 3.7 cu. ft. Washer
I have a Maytag EpicZ. It is giving me error code F20. What do I do?
its a reaction code try unplugging the washer for ten minutes then try it again let me know how it goes
merry christmas
Dec 21, 2010 | Maytag Washing Machines
My washer turns on all the light go on but when i start the washer it turns off
Check for codes Temperator sensor wire may have fell off back of drum code F-24
Nov 05, 2010 | Maytag EPICz 3.7 cu. ft. Washer
Codes F-21 And F-33 are showing up
this error occurs if the touch-pad/led assembly is not able to transmit/receive data to/from the central control unit (CCU) 1 check the touch -pad/led assembly by selecting different cycles and changing the modifiers and options available to confrim the touch-pad/led is responding. 2 unplug washer or disconnect power. 3 check wire harness connections to the touch-pad/led assembly and central control unit (CCU) now to the f-33 code system leak if after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR if the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. press PAUSE/CANCEL twice to clear the display. possible causes/procedure 1 check for crack or holes in the washer tub and pressure switch hose. 2 replace components if necessary good luck
Feb 16, 2010 | Maytag EPICz 3.7 cu. ft. Washer
Any idea what F 21 code means
When Washer drain time exceeds 8 minutes the water valves turn off and code F 21 is set.
Dec 21, 2009 | Maytag EPICz 6.7 Cu. Ft. King-Size...
F 21 error code? Maytag epic z washer
The F21 code on the Maytag EPIC is indicative of a pump problem. The pump impellers should be checked, there should be four of them. Sometimes the impeller blades can be broken by coins, or other items. Make sure that the pump is clear of debris, then remove the discharge hose, and blow through it.
If after clearing the initial slug of water, the hose doesn't blow free and clear, you have something stuck in there.
Nov 28, 2009 | Maytag EPICz Electric Dryer
"Maytag Epic z washer flashes f 24 error code"
I have a maytag epic z dryer and it wont turn on. it worked fine the last load, now nothing? help.
Apr 25, 2009 | Maytag EPICz Electric Dryer
Error code
I could not find error f01 for maytag, but for for whirlpool, it means CCM(central control unit) unplug washer for 2 minutes then try it.
Jul 12, 2008 | Maytag EPICz Electric Dryer
Maytag EPIC MFW9700S Front Load Washer Logo
1,166 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
