Question about Garden
Changing oil on a Tecumseh 3.5 HP engine used for a high-pressure water sprayer - what grade oil to use and what spark plug is required
  • 3,600 Answers
30 weight detergent oil.
Posted on Jun 26, 2009
Does a 2/3 HP .40GPM Campbell Hausfeld Airless Paint Sprayer require any kind of oil if so what kind and how much
airless sprayers have a pump that pumps the paint through a jet at pressure . there is no oil and it is vital that when finished that the pump be spotless after cleaning
Nov 12, 2015 | Campbell Hausfeld Air Tools & Compressors
Is it hard to change a magneto on a 5.5 hp Tecumseh engine?
How old is the gas in the tank? If it is older than 2 months drain it out and put in fresh gas and try again. Have you seen spark jump across the spark plug gap? To check for spark I use a spark checker. One end goes to the plug and the other to the spark plug lead. If you have spark you see a light flash which is more easy to see.
Sep 16, 2014 | Tecumseh Engine 5.5hp Horizontal OHV MTD...
Rigid 3300psi Pressure Washer chokes after engine warms up. Then looses water pressure. What is the problem and can I fix it?
if the engine slows then so will the pump... and so will the pump power.
engines are all the same and so just google "servicing engines"
an engine requires fuel - air - ignition and compression......
if your engine starts and runs then it must have reasonable compression so check / replace / clean the fuel and air filters...
check the condition of the spark plug / clean it / replace it
after these basic checks you move onto measuring the compression and checking the carburettor which requires a level of skill you may not have
oh, check the oil too !
if you have a make and model of engine (not pressure washer) the manufacturer may have service kits and service manuals... briggs and stratton / honda / tecumseh (you'll be lucky) / sumec linhai
Aug 30, 2013 | Legacy Extension,angled Rigid - LEGACY
Oil pressure light comes on.. what do i do?
Could be a few things but you should start off by checking the level of your oil. Make sure it is in the safe area
Nov 16, 2010 | 2001 Volkswagen Golf
Oil pressure is high should I do an oil change or will that help at all?
Oil pressure is the amount of hydraulic force used to move the oil through the engine parts. High pressure can be caused by
  1. wrong type of oil, 50 weight in an engine thatshould have 5W-30,
  2. plugged part of the oil system,
  3. sludge in oil passages or very dirty oil filter,
  4. internal engine part(s) being out of tolerance,
  5. clearances too tight on bearings or oil pump, or
  6. faulty sending unit or
  7. Gauge just showing high pressure.
So the first way to check is by just changing the oil, go ahead and do it. It might fix the problem.
Nov 17, 2009 | Office Equipment & Supplies
I am geting oil in my air intaket
Check any crankcase venting used on your engine (pcv valve, breather system etc) if any are plugged it will develop positive pressure inside that will drive oil out. If venting is clear, you can have a worn or broken piston ring which will allow compression to enter oil pan which cannot be eliminated by vent system. Generally though you would have plug fouling on any cylinder with that problem. Overall ring wear from time and miles can also contribute to this condition...slight wear in all cylinders can amount to a certain amount of "blowby" which in total cannot be eliminated by venting system. In that case, if condition is not severe, sometimes changing to a high mileage type oil, a synthetic, or using an additive like marvel oil can slow down, stop or slowly reverse some of the problem.
What not to do: Do not use a single grade or heavier single grade oil...in general this will worsen the problem.
Sep 04, 2009 | 2000 Ford F250 Super Duty Crew Cabs
High fuel consumption , even after changin plugs/filter/Eng.oil/cvt gear oil and cleaning the throtle
Checked brakes for possible wheel(s) dragging, as well as tire pressures up to max recommended pressure, and observe if tire wear unusual, signifying improper alignment? Any difference in engine oil grade used?
May 13, 2009 | 1999 Honda Civic
The pressure decreases when trying to wash
Dear rjrdiaz1013,
First you must find out where the real problem is. So first you must see that the engine works smoothly.(checking spark plug, spark plug gap, fuel mixture..etc..etc..). You have to do this by having no load at the pump. So remove water inlet hose and gun. If you manage to get the engine running smoothly,...then for sure you must service the pump. The pressure usually decreases from a faulty "Spill Valve". When the gun is closed the spill valve compresses and lets water circulate. When the gun is opened, the spill valve extends and closes an opening at its end. If this opening is not closing correctly, then the water keeps circulating and hence no pressure. My advice change the 'Spill Valve" by a new one. If the pressure is not 100%...then the next step change the suction valves. To change the suction valves, you must also change the high pressure and low pressure seals. Also better to change oil and oil seals. BUT the pistons must be examined. If the pistons have damage and cracks, these must be renewed, because they will ruin again the seals. In problems like these, I always fix the problem by changing the Spill Valve and the suction valves if need be.
When all necessary service is done, always try to start the machine with no load first. Also inportant that all seals and spill valve must be lubricated with the correct silicon grease.
Regards,
Fulltech.
Apr 21, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Garden Logo
850 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
