Vehicle Parts & Accessories Logo
A
Anonymous Posted on Jun 18, 2014
Why does my engine overheat with AC on?
On the interstate running 70 mph
Rweber
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Feb 13, 2015
 Rweber
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
5552
Points
25
It's most likely a fan switch, the fan has multiple speeds and when the AC is turned on it should jump to the highest fan speed but if it's not working properly the fan will, in some cases shut off when it needs to be on
buzz flewhart
Level 3:
  • Master 655 Answers
  • Posted on Sep 06, 2014
buzz flewhart
Master
Level 3:
Answers
655
Questions
0
Helped
193506
Points
1844
Does it only overheat on the highway? What about around town at lower speeds. Do the cooling fans kick in when it overheats?
What is the vehicle make/model? More information please...
1994 Chrysler Lebaron Convertible In traffic with
If the cooling system is functional, yes.
The ac condenser adds heat to the air coming thru the radiator when the ac is on. If the engine cooling system is weak, the extra heat will make the engine run hot.
Low coolant flow thru the radiator is a common cause.
2000 honda accord 5 speed rpm rev at 70 mph
Standard Shift? Clutch is Slipping
Automatic? It is coming out of gear or slipping
If it is an automatic-- you most likely will end
up having to rebuild it,if it is original since built for yr 2000
1helpful
I have a 2005 ford expedition and this morning while I was accelerating onto the interstate it started to sputter or **** between 60 and 70 mph. It stopped once I hit 70 mph but then my yellow engine...
the flashing light means you have a miss fire in the engine. You probably have a coil bad. Each cylinder has its own coil. My suggestion would be to go to a parts store and let them scan to tell you which cylinder, then change the coil. If thats not it then you have a bad injector
1helpful
Driving about 75 mph on interstate and all the sudden engine light comes on and monitor says reducing power to engine. Temp gauge skyrockets and cant drive over 30 mph...?!?!
The temp overheat could have been a false readiing due to a leak or low coolant level in the degas bottle(coolant expansion tank). The overheat signal is what induced the reduced power setting from the computer. Have your degas bottle checked at a dealership or by a competent mechcanic.
1helpful
Driving down interstate at 70 mph car suddenly
i would start in fuse and relay area with voltmeter.
1helpful
2answers
Bad milage
that sounds about right to me, and if you run that fuel with ethanol in it that does not help either
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
