Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
How can I open a LaCie B350 External Hard Drive?
You can carefully pry the bottom off with a screwdriver and remove the drive.  No problem using a "USB to IDE/SATA cable" ( Here's the first hit on Google: http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002  Worth $20. ) to copy off your data.  Or you could mount in your desktop PC.
Rob
Posted on Aug 05, 2009
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
How do I put my downloaded movies into Lacie hard drive 160
if its on a flash or C drive....... go to my computer open the folder with the movie(s).....go back to start my computer open the external hard drive (where you are going to put the movie)..... now copy and paste or click and drag from (flash or C) to external......what ever software you are using to download the movie(s) you can also change the download location to the external (now you will download directly to external)
Jan 23, 2011 | LaCie (300728U) 250 GB Hard Drive
I bought a few years ago a Lacie d2 safe hard drive with AES Encryption (with biometric fingerprint sensor). Currently not my Toshiba desktop or IBM laptop pick up the hard drive when I switch it on. The...
Hi... Problem with your external hard drive, pc don't recognize it...
it possible you have bad sector in your disk drive, or your usb cable is not responding.... the best way to find out open your box then take off our hard drive and install it into a pc and see if the hard drive work... or you box it self the controller inside our external box maybe damage,
Oct 20, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Hi ,my name is sameer i have 120gb lacie external hard disk,but is not suporting usb cable how can i change case pls help.............
just open your external HDD case, look for the connector (SATA or IDE), so buy new external harddisk case according the connector type.
Dec 20, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
I have a lacie design by F.A. Porsche 250Gig Hard drive - It has failed and is making a buzzing sound follwed by a beep - is this repairable?
Sounds like the hard drive in the Lacie has fauled.
You can install a new hard drive in the Lacie and then format in FAT32.
Sep 10, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Can't open folders in same window
it is a trojan download trojan remover and also run malawarebytes they are free and safe to use
May 07, 2009 | LaCie 320GB P3 Firewire External FireWire...
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
External hard drive not openning
Good News, Your data is probably still safe. Go to best buy or online and buy a new cheap external usb case for your harddrive. you can find them for about 7-25 bucks. Make sure you get the right one for the hard drive in your lacie. Take the hard drive out of the lacie case and put it in the cheap case and you will have your data back. I had this happen to me before. If you need help just ask me... Hope this helps you
George
Jul 15, 2008 | Computers & Internet
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
364 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
