Question about HP DeskJet 5550 InkJet Printer
Iron on transfers
How do i fix the settings to reverse the image so that i can use/print images on iron on transfers
    President:
  • HP Master
  • 1,996 Answers
What you want is called mirror image. It's on teh layout tab in your print settings (see here)
User manual for your printer here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 26, 2009
Printing mirror image
Check for the printer settings, if it has mirror image feature. Other wise, or try once below settings:
To reverse an image for iron-on transfers
1. On the File menu in your software application, click Print.
2. Make sure the product is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Click the Features tab.
5. In the Paper Type drop-down list, click More, and then select HP Iron-on Transfer
from the list.
6. If the selected size is not what you want, click an appropriate size in the Size list.
7. Click the Advanced tab.
8. In the Features area, select the Mirror Image check box.
9. Click OK, and then click Print or OK in the Print dialog box.
You can avail our technical services by visiting our website; http://www.vtechsquad.com.
Apr 25, 2013 | Casio Canon PIXMA MP480 USB 2.0 All-in-One...
Using a C3100 series HP inkjet printer, I'm trying to print HP Iron-on Transfer Paper but when I select that option, I cannot get the appropriate reverse image need for ironing on the transfer. What's...
The steps vary by printer. I've got a c7280 installed and the options for me are to click Print > Preferences > Advanced > Mirror image. When you click on Mirror image, you change it from 'off' to 'on'. Click OK to save the setting and print. Be sure to change it back after you're done printing your transfers.
I am an HP employee. I do not represent HP on this site.
Sep 14, 2010 | HP Photosmart C3180 All-In-One InkJet...
Where is my mirror image feature?
Looking at the User Guide, it appears that the Mirror Image option may require you to select "Iron-on transfer" as the paper type (see p. 96 in chapter 7):
1.
2. Make sure the HP All-in-One is the selected printer.
from the list.
8. In the Printer Features area, select On from the Mirror Image drop-down list.
Jun 25, 2010 | HP Photosmart C7280 Laser Printer
Printing letters from the computer to a iron on
You don't. Once you have completed your design including the text as it should read when the T Shirt is finished you go to print the design. When the printer dialogue appears then you Click Preferences, Properties, Options, or Setup (depending on the program or operating system) then choose the paper type as the T-Shirt Transfer option if you have one setup so that the print image will automatically be reversed when printed, or you choose an option to flip the image horizontally, or print reverse.
Oct 21, 2009 | Dell 924 All-in-One InkJet Printer
How print iron on transfers
Yes, you need to "MIRROR" the image. Go to printer properties and select the ADVANCED TAB. Click on the MIRROR setting then print onto the transfer paper. The image should print out backwards like you are looking at it in a mirror. When you iron it onto a shirt, it will come out correct.
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
What would cause it to print everything in reverse?
You have probably got the Preferences set to "Mirror Image".
Next time you go to print something, click on Properties or Preferences when the Print window comes up.
Click on the Advanced tab. Look for Mirror Image. It should say Off. If it is ON, click on the word "On" and a drop-down menu will appear to select Off. Then click OK at the bottom.
You can then cancel the print job, or go ahead and print it out to verify that the printing is OK.
Mirror Image is used mainly for T-shirt iron-on transfer images.
Thanks for using Fixya.
Jun 12, 2009 | HP Officejet Pro L7680 All-In-One Printer
How do I select mirror image (reverse image) from HP Photsmart
When you select Print and the Print window opens, select Preferences.
Click on the Advanced tab. Look for the "Mirror Image" option. It should be "Off". If you click on "Off" the drop down menu should appear to change it to "On". Click "OK" at the bottom. Then click "Print" on the Print window.
Don't forget to change it back when you are done. :-)
(Note: If the Mirror Image option is not on the Advanced tab, look on the Effects tab.)
Apr 22, 2009 | HP Photosmart C7280 Laser Printer
Setting up printer for reverse/mirror printing
I used to use iron on transfers all the time for different things. The setting is usually available whan you attempt to print the image you have different options in properties. Under the advanced tab in printer properties there is something called media type. You can set this to iron on transfer. To locate printer properties in XP for example go to Start>Control Panel>printers>view all printers right click on the printer you intend to use and select properties.
Mar 12, 2009 | Canon Office Equipment & Supplies
How do I paint an image for iron-on transfer with the image reverse i.e. mirror image? On a Pisma 6600D
In the Printing Options/Printing Preferences box, Main tab, select T-Shirt Transfers as Media Type.
May 05, 2008 | Office Equipment & Supplies
HP DeskJet 5550 InkJet Printer Logo
270 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
