Question about Kenmore 64902 Electric Dryer
Dryer gets too hot runs about two minutes and
Kenmore dryer gets too hot runs about two minutes and shuts off?
  • Anonymous Mar 25, 2014
    runs for about an hour
    Problem Solver:
  • 16 Answers
In the back of dryer you have therm,ostats that are malfuctuioning ,need to replace them
Posted on Jun 27, 2009
My dryer runs for about 10-20 minutes then shuts off because it must be overheating. After it cools down I can run it again. Is that an element problem?
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 01, 2011 | Kenmore Dryers
Dryer runs for about 5 minutes then shuts off the clothes are hot
Your vent may be obstructed causing the dryer to trip, once it cools down it will reset itself. The way to see if thats the problem is to disconnect the vent and run the machine, if it doesn't shut off, you will need to clear the vent.
May 13, 2011 | Kenmore Elite HE4 Electric Dryer
Dryer shuts off after about 10 minutes. Motor feels hot, real hot. I think it is overheating and shutting off. The lower the setting the longer it will run. Is it the Thermal fuse or thermostat?
There might be a problem with the bushing of the dryer motor that causes the rotor to become shorted with the magnetic field and that's the reason why it becomes too hot. It is also the reason why the thermostat shuts off the motor when it becomes too hot to avoid overheating. Replace the bushing of your motor.
Nov 10, 2010 | Kenmore 63942 Dryer
My Kenmore dryer runs for for ten minutes then shuts off. It also pops the circuit breaker. The drawer runs fine and then just turns off. Heats up. Lint is all clear, but don't know why it shuts off?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Either the motor gets hot and blows the breaker or if it is electric the heater element gets hot and then shorts out...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2010 | Kenmore Dryers
Our kenmore eliite HE4 gas dryer keeps shutting off after a few minutes of running no mattter what heat setting we put it on. On air dry mode it works. Is this a high heat sensor problem? The unit is 4...
You didn't mention if the dryer is getting hot.
If is getting hot, then shutting off, I agree with you.
If it is NOT getting hot, I would suspect the IGNITER ASSY
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
Jul 22, 2009 | Dryers
DRYER STARTS BUT IMMEDIATELY SHUTS OFF
If you are having the same problem I had, the motor gets hot and shuts off. My motor was making a fairly loud noise when I cut it on. It would run for a minute or two and then shut off. I had to replace the motor. Motors are fairly cheap and not that hard to install. I paid $50 for a new one on ebay including shipping.
Jul 18, 2009 | Kenmore 63942 Dryer
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Kenmore 64902 Electric Dryer Logo
182 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
