Microsoft Windows Server Standard 2003 for PC Logo
Posted on Nov 06, 2007
Active directory how to take the active directory backup
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Nov 15, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
2342
Points
21
You can use in built ntbackup utility.
In a DC, in the Items to backup window, expand Mycomputer and you can see System state. select that and proceed. It will take the Active Directory data.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Oct 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
4998
Points
7
To back up System State data using the Backup Wizard
  1. From the Start menu, click Run , and then type Ntbackup .
  2. On the Tools menu, click Backup Wizard .
  3. Click Next , click Only back up the System State data , and then click Next .
  4. Designate where you want to save the System State data, click Next , and then click Finish .
  5. When you are done setting options, click Finish .
    Hope this helps.
    Piyush
    Lepide
A
Anonymous
We can take the ntds folder backup also
A
Anonymous
Uses the backup tool built into WIndows server
2 Related Answers
Anonymous
  • 117 Answers
  • Posted on Mar 24, 2008
SOURCE: System State Backup problem
That specific error pertains to "validating" your copy of Windows. you might want to validate that copy, then re-try system state.
~~Jasta~~
Anonymous
  • 126 Answers
  • Posted on Feb 16, 2009
SOURCE: how to take active directory backup?
hi,welcome to fixya
ok i just checked it out and what i got for u is that u can try and go to this website and check it out,
http://www.backupassist.com/adwords/server-backup.html?gclid=CLKuk4bB4ZgCFZgtpAodo3ePDw
OR go to this website and check it out and this might be helpful for u,
http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/distrib/dsbj_brr_axal.mspx?mfr=true
OR try this out
http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/distrib/dsbj_brr_ixwo.mspx?mfr=true
pls rate this solution.......thanks
How can I delete multiple students simultaneously
First of all where are the accounts othe students located. On Active Directory? If yes log on to the server and go to Active Directory Users and Computers, then go to the Organizational Unit where the user accounts are of the one to be deleted. You can click on one user account ,then to delete multiple users just hold down control button and continue to click the user accounts you want deleted. the right click on the blue part and delete. NOTE: Always make a backup of the users/students you want deleted. you could need their data later again
We know that while installing active directory a domain user works on the server and gets the interface of his os can any one tell me how can i take backup of the the whole domain from server only
I believe you are asking for instruction on how to backup your Active Directory domain from the server, correct? The best way to do this is to use a third-party utility like Symantec's BackUp Exec and perform a System State backup.
Although Windows comes with a basic backup utility, your best bet is to go with a third party tool.
I hope this helps!
How to repair dsa.msc it is not working
Reboot your DC in Directory Services restore mode and then try again. If you have a backup, then restore the backup.
Let me know if you have any queries.
Regards,
Abhay.
How to take active directory backup?
hi,welcome to fixya
OR try this out
How to take a back up for active directory?
there is no backup for Active Directory only. you can backup the PDC or the BDC as a whole. or to backup the system state data.
Active Directory is same as registry. backup the AD will help you any when the machine goes down. you don't have the link to all of the services.
2helpful
4answers
DNS
DNS is the primary name resolution service for Windows Server 2003. Active Directory depends on DNS for domain controller location, and DNS influences Active Directory domain naming. Thus, to fully understand Active Directory, it helps to understand how DNS acts as an integral component in the design of Active Directory.
DNS provides Active Directory with both a name resolution service for domain controller location and a hierarchical design that Active Directory leverages to provide a naming convention that can reflect organizational structure.
Typically, a DNS domain namespace deployed to accommodate the Active Directory mirrors the Active Directory domain namespace. In cases where there is an existing DNS namespace prior to Active Directory deployment, the DNS namespace is typically partitioned for Active Directory, and a DNS subdomain and delegation for the Active Directory forest root is created. Additional DNS domain names are then added for each Active Directory child domain.
DNS data is used to support the location of Active Directory domain controllers also. During or after the creation of the DNS zones used to support Active Directory domains, the zones are populated with DNS resource records that enable network hosts and services to locate Active Directory domain controllers.
PS: As sourced from Microsoft Technet Site
Regarding ActiveDirectory Services in Windows system
Active Directory (AD) is a technology created by Microsoft that provides a variety of network services, including: using the same database, for use primarily in Windows environments. Active Directory also allows administrators to assign policies, deploy software, and apply critical updates to an organization. Active Directory stores information and settings in a central database. Active Directory networks can vary from a small installation with a few hundred objects, to a large installation with millions of objects (though not easily [3]).
Active Directory was previewed in 1996, released first with Windows 2000 Server edition, and revised to extend functionality and improve administration in Windows Server 2003. Additional improvements were made in both Windows Server 2003 R2 and Windows Server 2008.
Active Directory was called NTDS (NT Directory Service) in older Microsoft documents. This name can still be seen in some AD binaries.
There is a common misconception that Active Directory provides software distribution. Software distribution is run by a separate service that uses additional proprietary schema attributes that work in conjunction with the LDAP protocol. Active Directory does not automate software distribution, but provides a mechanism by which other services can provide software distribution.
~~Jasta~~
2helpful
2answers
Window 2003 AD NTBackup Problem
Reboot into Directory Services Restore Mode (F8 at startup) and use NTDSUTIL
to check the integrity of your database. Usually, an offline defrag will
fix this kind of error. If it doesn't, and the integrity checks fail,
you'll need to try and repair. Note that there could be issues with the
repair so be prepared to restore from backup.
Google NTDSUTIL for the syntax. There's loads of info. on TechNet2.
1helpful
Backup DHCP,AD of win 2000 .
How To Use the Backup Program to Back Up and Restore the System State in Windows 2000 var sectionFilter = "type != 'notice' && type != 'securedata' && type != 'querywords'"; var tocArrow = "/library/images/support/kbgraphics/public/en-us/downarrow.gif"; var depthLimit = 10; var depth3Limit = 10; var depth4Limit = 5; var depth5Limit = 3; var tocEntryMinimum = 1; .toc{display: none;} SUMMARY loadTOCNode(1, 'summary'); This article describes how you can optionally back up the system state in the Windows 2000 Backup program to back up and restore critical system data. When you choose to back up the system state on a domain controller, the following items are included: • Active Directory (NTDS) • The boot files • The COM+ class registration database • The registry • The system volume (SYSVOL)When you back up the system state on a non-domain controller, the following items are included: • The Boot file • The COM+ class registration database • The registryWhen you back up a member server or domain controller with Certificate Server installed, the following additional item is also included: • Certificate ServerWindows 2000 Backup can back up and restore Active Directory on Windows 2000 domain controllers. You can perform a backup operation while the domain controller is online. You can perform a restore operation only when the domain controller is booted into Directory Services Restore mode (by pressing the F8 key when the server is booting).
uparrow.gifBack to the top
How to Back Up the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 2. Click the Backup tab. 3. Click to select the System State check box. (All of the components to be backed up are listed in the right pane. You cannot individually select each item.)
NOTE: During the system state backup, you must select to back up the Winnt\Sysvol folder. You must also select this option during the restore operation to have a working sysvol after the recovery.The following information applies only to domain controllers. You can restore member servers the same way, but in normal mode.
If any of the following conditions are not met, the system state is not restored. Backup attempts to restore the system state, but does not succeed. • The drive letter on which the %SystemRoot% folder is located must be the same as when it was backed up. • The %SystemRoot% folder must be the same folder as when it was backed up. • If sysvol or other Active Directory databases were located on another volume, they must exist and have the same drive letters also. The size of the volume does not matter. uparrow.gifBack to the top
How to Restore the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. To restore the system state on a domain controller, first start the computer in Directory Services Restore Mode. To do so, restart the computer and press the F8 key when you see the Boot menu. 2. Choose Directory Services Restore Mode. 3. Choose the Windows 2000 installation you are going to recover, and then press ENTER. 4. At the logon prompt, supply the Directory Services Restore mode credentials you supplied during the Dcpromo.exe process. 5. Click OK to acknowledge that you are using Safe mode. 6. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 7. Click the Restore tab. 8. Click the appropriate backup media and the system state to restore.
NOTE: During the restore operation, the Winnt\Sysvol folder must also be selected to be restored to have a working sysvol after the recovery process. Be sure that the advanced option to restore "junction points and data" is also selected prior to the restore. This ensures that sysvol junction points are re-created. 9. In the Restore Files to box, click Original Location.
NOTE: When you choose to restore a file to an alternative location or to a single file, not all system state data is restored. These options are used mostly for boot files or registry keys. 10. Click Start Restore. 11. After the restore process is finished, restart the computer.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
