Question about Motorola Mobility H700 Wireless Headset
Earpiece holder around ear seperated - soft rubber from plastic.
Where do I get a replacement snap-in new earpiece to put on my H700. The part I speak into works fine - it's the wraparound the ear piece that seperated. Any outlets known?
    President:
  • 1,114 Answers
If you go to your cellular providers retail location, they have a customer service desk for repairs, etc. they will have parts. Hope this helps
Posted on Jun 26, 2009
Headset earpiece assembly has become detached from headband assembly. The post does not want to go back into the hole on the earpiece assembly bracket. What do I do?
The headband post can only be inserted into the earpiece when the earpiece has been sufficiently rotated. (Note that the hole and post are a 'D' shape, not round.) The installed ear cushion is preventing you from rotating the earpiece sufficiently.
Remove the ear cushion from the earpiece by carefully pulling it off so you do not damage the clips that hold it on or the gasket material between the cushion and the earpiece. There are six clips, three on each side.
Now you can rotate the earpiece into the position where the headband post can be inserted into the earpiece.
Carefully reinstall the ear cushion by pressing it onto the plastic clips. Note that it can only be installed one way with the internal plastic support towards the headband.
Oct 01, 2013 | Bose QuietComfort 3 Acoustic Noise...
How do I replace the ear cushions for a Plantronics DSP 400? Does the ear piece detach? Can't find a manual either.
There are some small silver inserts on the side of each earpiece. You can pry them off (gently) starting under the cushion and working your way around.
You can then remove the old cushions and put in the replacements and snap these silver retainer inserts back on.
You can get replacement cushions online for about $16.
Oct 14, 2009 | Plantronics DSP-400 Headset
Motorola H700 and iPhone 3G S - people can't hear me
Bump. I have the same problem - same headset, same 3GS.
Jul 27, 2009 | Motorola Mobility H700 Wireless Headset
I need a replacement earhook for my Jabra VBT2050 Bluetooth
I have not found one for sale. Even if I did find one, I'd probably lose it like the old one or break it since it's plastic.
Go to Radio Shack and get some "heat shrink tube" Put it over the metal and warm it up. It will shrink and cover the sharp edges. It's soft, black plastic.
Be sure to shape it to your ear before you wrap it around the Bluetooth earpiece. Then just tighten it with pliers and never have to worry about it again.
Jul 12, 2009 | Jabra Bluetooth Headset with Adjustable...
Reposition boon
hello! take the ear piece and unfold it to 45 degrees, than pull it off . see the little splits on the end where the earpeace goes onto the body off the tooth? thats motos design for slipping it off the pins. than turn the earpiece around and put er back on. a little bit of a tussle till you get use to it. if your confused as i was put the earpeace on your other ear and the light will turn on and youll go (like me) oh yea!! i see, than youll go easy breezy. good luck. m.m.
Jan 27, 2009 | Motorola Mobility H700 Wireless Headset
Hearing from Motorola H700
good morning!! ive been thru this before, try tapping your phone volume while your talking to your party, it shold be seen on your phone screen as earpiece volume than turn it up and when you have the volume where you want it dont forget to tap the set on your phone, another prob i had was some times there is a small protective plastic film on the ear holes on the tooth and one on the mike sometimes, i could hear my party but they couldnt hear me until i discovered that lil peice of plastic. remember your key codes are either 0000 or 1234. good luck m.m.
Jan 26, 2009 | Motorola Mobility H700 Wireless Headset
I evidently dropped my Motorola H700 Earpiece and lost Mic Cover
as far as I know yu have to buy a new one but if you do find out that you can just buy the mic. please let me know
Dec 08, 2008 | Motorola Mobility H700 Wireless Headset
Changing earpiece
•First take your  device and hold it vertical.
•Looking at the earpiece that ressembles somewhat Alladin lamp, it's tip is positioned either at past 20 (for right ear) or before 20 (for left ear).
•Depending if it's one side or the other, you should turn the earpiece clockwise to 30 or counterclockwise to 30. So the "tip of the lamp", which is the ear channel of the earpiece in fact, is indeed at 30 past the hour.
•Then pull it out with a round motion downward, assuming the upper part is the blue light.
You can then change the side of the ear wire and or the earpiece for a different size supplied by RIM when you bought the device. I don't know how/where to get new earpieces. They don't seem to sell them separately...which is rather frustrating considering the price they sell this device!
Sep 03, 2008 | RIM BlackBerry 8100 HS-655 Bluetooth...
Wep210 headset
needs to have the earpiece redsigned like the headphones provided for the radio on g600 model can i swap my we200 for a redisigned one like that please
Dec 27, 2007 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Bluetooth repair
i have a blue tooth motorola h350 and it just quit working it's under a year old can you get me the 800 number so i can get it replaced
Dec 10, 2007 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Motorola Mobility H700 Wireless Headset Logo
432 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
