Question about Raymarine A65 Combo GPS Chartplotter/Fishfinder
Log and trip function not registering
I have a A65 chartplotter on which the log and trip function does not is the second unit with the same problem all other functions work
how can I solve the problem?
  • 16 Answers
It is unlikely the problem is in the A65 screen.....most likely it is an issue with the paddlewheel itself, its circuit in the depth/speed transducer, or least likely, in the DSM25 sounder module.
Both the log and the trip functiions are read from the paddle-wheel sensor of the connected DSM25 sounder module and transducer.
1. Make sure you have a DSM25 sounder module and transducer with a paddle wheel (the A65 is available without the DSM25 option.)
Double check the connections between the DSM25 and the A65, as well as the transducer connection to the A65. There is an indicator light on the DSM25 to confirm it is on.
2. Make sure the paddle wheel turns freely. They tend to get fouled easily with debris and growth.
3. Make sure the A65 is giving to a reading for SPEED when underway or when having a buddy spin the paddlewheel by hand. Do not confuse SPEED with SOG. SPEED is from the paddlewheel.....SOG (Speed over ground) comes from your GPS sensor and is not used by A65 for log or trip purposes.
If you get npo speed reading at all the paddle wheel may be defective or the depth/speed transducer may be defective. See your dealer about a replacement.
Posted on Dec 28, 2007
When i tun on my raymarine a65 ,i get gray and white lightly shaded vertical lines. what is the problem
Check cable connections, reseat all at both ends(so say the book) Now disconnect all cables, CAREFULLY open the housing, visually check internally.Perform as a surgeon would do, reseat all connections(flex cable,wiring,IC's,& the liquid crystal LCD display) clean as necessary with electronic spray cleaner & red eraser. Reassemble. Reconnect. Good Luck.(definition of 'reseat'- unplug or move unit in socket to reconnect the components leads)
Nov 02, 2015 | Raymarine A65 Chartplotter Fishfinder...
Why does the casio qt6000 saying wrong operator
You are not logged in . Either you log in or you de-activate the clerk function
Nov 11, 2012 | Casio QT-6000 Cash Register
TEC MA-1650 Cash Register It appears the register has been put into a sub programming mode somehow and we are unable to get register functional again. When Register is switched to Set there is a P...
Perform a status clear.
turn key to blind(must be S key not mgr key) while holding zero key down turn reg on with power switch on right side.
reg will beep once & print reciept saying status clear.
this wil not clear programs or totals.
Dec 12, 2010 | Office Equipment & Supplies
Likely your DSM25 (that little box that connects the transducer to the display) will need to be rebuilt. The red LED is saying that there is an internal fault with the unit. You would need to send the unit in for repair through Raymarine (as there really is not anyone else who can do it), and they would have to replace the main circuit card in the box. I believe that they are charging either $150 or $175 to repair those now... but likely the only way you will get that one to work again.
Jul 27, 2010 | Raymarine A65 Combo GPS...
Did you cancel the current trip and restart the GPS? Try one of your preset waypoints and see if you are getting data that way. It may just need a reset, unplug and allow it to discharge first and let's see if that does it.
Jun 02, 2010 | Raymarine A65 Combo GPS...
Phone will not register with base
Would you try this procedure:-
First on the base and hold paging/register key for 3 seconds
Than on the hand unit select function key and open "MENU"
select "SETTING" from menu and confirm (Ok)
Selecect "HANDSET" and confirm
Than select" REGISTER" and confirm
than enter "0000" as pin and confirm..
it will flash and it detects the base.
Take care..
Nov 14, 2009 | Siemens Gigaset S440 Cordless Phone
I have a model KX-TG9332T.... I cannot get the handsets to link with the base...I have unplugged, moved the system, changed the batteries and both handsets continue to get the message cannot link to the...
Registering a unit Operating additional
Additional handsets
Up to 6 handsets can be registered to
the base unit.
L See page 6 for information on the
available model.
Registering a handset to a
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, register the handset.
{MENU} i {#}{1}{3}{0}
Base unit:
Press and hold {LOCATOR} for 4
seconds until the registration tone
L If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
L The next step should be
completed within 90 seconds.
Press {OK}, then wait until a long
beep sounds.
L While registering, "Base
registering" is displayed on all
registered handsets.
L When you purchase an additional
handset, refer to the additional
handset's installation manual for
Jan 18, 2018 | Panasonic Lands Phones
Hello! Our Raymarine A65 will not start up. It starts a boot process but does not show "Raymarine A65" on the display and no chart is displayed as it usually does. Regards Odd
Probably a bad printed circuit board, just had to send mine in to have it repaired. When I hit the power button, I did hear a beep, but then nothing displayed. Mine was still under warrenty, so don't know the repair cost if yours is not.
Jul 15, 2009 | Raymarine A65 Combo GPS...
No depth reading while on plane.
Depending on your transducer type, you may have a liquid filled type that simply needs refilling. If this is the case check for leaks and get it redone. If not it could be transducer placement or cavitation under the hull.
Jun 18, 2008 | Raymarine A65 Combo GPS...
Was the engine running when it shut off? How was the voltage at the time it failed? The A65 will shut down if the voltage drops below 11.2 volts.
Another common cause would be corrosion on the plug where it plugs into the back of the display, or the terminal connectors that attach it to the boat's power supply.
It could also be a bad crimp on the terminal connectors. Make sure connectors are the right size for the wire and that they are marine grade, such as Ancor brand connectors. I also recommend heat shrink style connectors,
I have not heard of any software issues for that model so I am betting it's a wiring issue. However, there is an update available from Raymarine. There were changes made to the WAAS satellites and the update helps it recognize the new satellites. You can download it for free from Raymarine. Copy it onto a blank CF card and plug it into the card slot on your GPS. When you turn the unit on it will prompt you on how to proceed with the update. It will fix any known software gliches at the same time.
I hope this answer helps. Please reply if you have any questions about my response.
Feb 25, 2008 | Raymarine A65 Combo GPS...
Raymarine A65 Combo GPS Chartplotter/Fishfinder Logo
230 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
