Question about Vestax Audio Players & Recorders
Need circuit diagram for Vestax VS1P Powered Monitor
I need to replace the laser on both cd players,but I dont know where to buy it.Help
Ignore the website certificate warning!
Virtual Sounds Technology - Vestax Parts - VST Service https://www.vstservice.com/c-40-vestax-parts.aspx We have the largest stock of New Vestax parts in the world. Period. If we dont have it, it either no longer exists or can only be pulled from a used unit.
Jan 19, 2016 | Vestax CDX05 CD Player
I need my usb port replaced on my vestax vci-300. Can you help?
The electronics of a USB port is fairly robust. Why do you think the USB port needs replacing? Or do you just mean the connector... Even those are fairly robust and if they wiggle, they may just need to be resoldered to the circuit board.
Sep 05, 2010 | Vestax Vci 100 Midi Controller
Need to change the fuse in a vestax pmc
Sorry, since the mixer is powered by a "wall wart" adapter, it is UNLIKELY there are fuses in the unit.
If it is inoperative, then check the voltage of your power adapter. If you by chance connected a wrong adapter, try the correct one. It is possible damage was done in this case that is not so easily fixed as changing a fuse. The correct adapter looks to be a type AC14 which LOOKS to be a 15 volt DC, 500 ma, with negative on the pin.
Jan 25, 2010 | Vestax Pmc 280 DJ Mixer
Connecting two powered mixers
Hi, If you have small electronics knowledge this might help you. First fine in each mixer the amplifiers line In if your mixer has two amplifiers then you have four line In. Disconnect this line from your mixer and build a circuit Line out multiflier. You can use op amp for this application this is a simple circuit. You made two input and four outputs. If you are interested i can send you a schematic diagram.
Aug 10, 2009 | Audio Players & Recorders
Circuit diagram
i need circuit diagram of 107e61/94 model.
Feb 19, 2008 | Philips 107E61 17" CRT Monitor
Samsung 591s monitor
It isn't getting a steady, usable source of power, you can try to diagnose this your self but it will be a power issue INSIDE the monitor within the circuit board
Jan 22, 2008 | SAMTRON 55V 15" CRT Monitor
Open Questions:
248 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
