Question about Kenmore 30169 Electric Single Oven
Hi have an electric Kenmore oven - did self cleaning and it started beeping with an F3 code
  • 15,935 Answers
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
We are using self clean feature. continuous beep about 20 minutes into cleaning screen shows F# locked door and beeps nonstop. what can we do to stop beeping but still proced with self cleaning?
F3 is a bad oven temp sensor. The sensor fail F3 code will appear if during self clean that it senses temps above 915F, or there is an open / short in the temp sensor. The only thing you can do is replace the sensor. Just getting the oven door open can be a real pain as you have unlatch the oven door lock to get to the screws that are in the top lip above the oven door so that you can change the sensor. Depending on model you may have to reach through a burner to manually unlatch the oven door lock or remove the side panel of the oven to manually unlatch the door lock. On most units It will not continue to self clean with an F3 code detected. Once an F3 code is detected the ERC shuts off power to the bake and broil elements so that it does not catch fire from a run away temperature condition.
Thanks for choosing FixYa,
Kelly
Nov 25, 2010 | Ovens
Have a Kenmore electric drop-in range less than 2 years old. Turned on self-clean cycle but after an hour or so started beeping and F3 was displayed. Have lost manual.. What does f3 mean?
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Aug 04, 2010 | Kenmore 42161 / 42169 Electric Single Oven
40494 / 40495 / 40499 Electric Single Oven: have a kenmore self cleaning electric range it was...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
May 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Getting an F3 code
try starting self clean again then cancle it
May 05, 2010 | Magic Chef 9815 Electric Single Oven
Kenmore double oven flashing "door locked"
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
My oven displays F3 and beeps
f3 error code is generally a bad oven sensor. not every code is universal, but most manufacturers use the f3 error code to indicate a sensor issue. it is an easy fix if you want to tackle the problem yourself. Joe
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 30169 Electric Single Oven Logo
73 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
