Question about Kenmore 63792 Microwave Oven
Kenmore model #110.92596100 serial #1645408 Washer will wash & empty tub, but no spin. The clothes are too wet. Pump replaced 2 yrs ago. When spin cycle is selected, I hear an abnormal clicking sound and no spin. The motor is working not spinning the drum.
Manual for kenmore washer model number 11026902690
Try this link: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11026902690/0582/0153200?pathTaken=&prst=0&shdMod=11026902690
Jan 13, 2014 | Kenmore Microwave Ovens
My washing machine do not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 31, 2011 | Microwave Ovens
I have a GE microwave model# jes737wm02 manufactured inFeb. 2009 it runs but won't cook
we purchased a ge microwave about 2 yrs ago & the paint is peeling on the inside. Is this dangerous & should we continue to use it?
Oct 28, 2010 | GE JES738 Microwave Oven
Washing machine not spinning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 08, 2010 | Siemens Microwave Ovens
Model #110.26901691 Kenmore washer. Need to
The end caps come off by placing your hand over the TOP of the console and lifting each one from the back and pulling forward. If you can't get them to come off by hand, try placing a screwdriver in the top groove in the back and give it a twist to pope the cap free. Once the caps are removed follow these steps:
1. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
2. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
3. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
4. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
If you are replacing the lid switch, you will now have full access to remove it from the under the washer casing.
To reinstall the washer case, follow these steps:
1. With the lid of the washer open, grasp the case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have any questions about this repair, please post back and let me know. You can view some excellent exploded view diagrams of your washer at searspartsdirect.com for assistance in locating parts if needed. I hope this helps you.
Dec 08, 2009 | Microwave Ovens
F 02 error
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. In most cases this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean if necessary. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Dec 07, 2009 | Microwave Ovens
I have an error code on my new LG LDF 6920st dishwasher. It runs for about 10 minutes and then dings and flasher LE
I would suggest calling the seller or distributor and having this unit replaced.
This error is not part of the consumer repair area and should only be done in A workshop here are two preevious ownrs experiences
1)
LE ERROR CODE
YOUR MOTOR RING CAME APRAT
THE UNIT EMPTIES AND REFILLS AND STOPS AT WHEN IT TRYS TO WASH I had to take the unit apart from the inside to comferm the motor is stuck. remove the racks the spinner in the bottom, the screen assy (1 foot in dia.) the wheel of pump with left hand threads, make sure it is unplugged, try to spin the garbage disspser blade. if it has trouble spinning then, pull out dish washer unit and flip over and remove the cover on botom and the motor and ground wire. good luck. i have had to replace mine twice now!
2)
I had the same problem and was told it was the motor. Well, it wasn't the motor. Take the front panel off & look at the wiring harness. There was a wire broken, not to mention the insulation was in the wrong place. It should be between the inside wall (dishwasher tub) and the wiring harness this way the wires wont get hot and break. Simple fix but, I would have never thought to take the door apart.
This unit is under warranty and should be attended to by the technicla support. LG are not good quality at any time, now made in Korea as cheaply as possible.
Please rate my help++++Thanks for using FIXYA
Nov 16, 2009 | Microwave Ovens
Kenmore Elite HE 3t washer - stops and flashes error code F 02
"F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. The washer will NOT complete a cycle with the condition present that is causing the error code. In most cases this means there is a clog in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
Nov 11, 2009 | Microwave Ovens
Kenmore 63792 Microwave Oven Logo
132 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
