Question about Kenwood VR-505 Receiver
IR receiver on unit not working?
I have been unable to control my VR-505 with the remote control for a long time now. Eliminating all obvious possibilities such as batteries, I attempted to program my Universal remote with every Kenwood code possible and can get no response. My next effort was to install an IR receiver kit using IR emitters, connecting block and IR receiver. My first assumption was that the remote was bad, but after installing the IR kit and trying a few buttons, the IR receiver on the kit flashes when using the Kenwood factory remote. That tells me that the remote is flashing Inferred out of it. And I assume that it is just the IR receiver on the VR-505 itself. How would I fix this? My next attempt was going to be to take apart the unit and resolder the connections, but before I went that indepth, I was looking for advice. Thanks in advance.
  • 2 more comments
  • sthomas1 Dec 25, 2007
    I cannot control the receiver even with a new remote . Can you help?
  • drewincanada Dec 27, 2007
    Same problem - the receiver responds intermittently to IR signals. Sometimes it works, sometimes it doesn't. Anyone have an idea?
  • Anonymous Jan 09, 2008
    I have a DIVSYS made IR receiver that won't work when attached to a nine volt battery and the test button is tapped!!!! please help!
  • Anonymous Dec 10, 2008
    remote not working for a very long time now and can't program the cable remote either. Obviously it is the receiver. What else can I do (I'm not tech savy so I need simple step by step instructions.
It seems to be a general problem on Kenwood Receivers. Pls check this out or this
regards sgershoj
Posted on Jan 08, 2008
Cannot get my reciever to turn on or operate with the remote control. Batteries are new.
It looks to be a "normal" problem with this model. I have two of them with the same problem. Solved ressondering IR receptor.
Sep 05, 2013 | Kenwood VR-505 Receiver
Remote on VR 505 work only part of the time
Remove battery on the remote and open the remote. clean the inside board of the remote , the battery terminals, the customer touch pads and contacts.
solder if you notice any poor joints, poor contacts. replace battery is voltage is low.
reset and check
Mar 29, 2011 | Kenwood VR-505 Receiver
We just got a new vizio tv and we have all the same receivers. we have a 722 receiver but the ir remote will not work.
Hello Daniel Busa with Dish Network customer service here. Vizio tv's almost always program to 505 so try this code first. To program this hold the clear tv button down for about 4 seconds the other mode buttons will light up. Once they are all lit hit 505 and pound. If that doesn't take care of it use this link:
Dec 25, 2010 | DISH Network IR Remote Control
I have a kenwood sorround sound and the remote will not work. The remote unit is RC-R0511.
I had the same issue on my VR-505 and here is how I fixed it. I found the fix on a different site and kudos to Plazman30 for posting it!
Jan 14, 2010 | Kenwood VR-505 Receiver
Kenwood VR-6070: Broken volume knob; will IR sensor still work?
Looks like you have several faults?
First try to fix the remote:
May 28, 2009 | Kenwood VR-6070 Receiver
Receiver does not sense the remote even after buying a new remote.
I have had this problem, and found this on FixYa during a google query. The only other solution caused me to stop and check it out, but there is not enough information to really repair the receiver.
I found another page through another forum that showed me how to fix my receiver, and I now have a functioning remote control after many years without.
The original page with all the info is : . I reproduce it here as we all know web pages can easily disappear. I make no claim other than the fix worked for me, too.
I quote his page below:
How to fix the remote control problem with the Kenwood VR-507 Receiver The Kenwood VR-507 receiver has a very high remote control failure rate. The issue is not with the remote control itself, but with the IR receiver on circuit board inside the receiver.
Well, my friends, there is HOPE! A simple resolder of the three pins for the IR receiver will quite happily fix the problem quite premanently.
All you need to do, is remove all the screws that holds the cover on, and remove it.
The you can remove the front of the receiver from the frame and lay it down somewhere to work on. There are some wires you will need to disconnect. Make sure you mark them, so that you reconnect the to proper spot later.
Then, looking at the handy picture below, you should see exactly which pins need to be resoldered! I have sent this picture to 4 different people and resoldering has fixed the problem for ALL of them.
Here is the picture of part of the circuit board:
resolder.jpg Once you're done resoldering, put it together, hook it up, grab a beer and the remote and resume proper couch potato stance!
Dec 25, 2007 | Kenwood VR-505 Receiver
Sounds to me like the issue is the rx in the unit. It can be fixed with very little work if you can locate the part. Let me take a look and see if I can locate the part number for you. Although I have to say that Kenwwod can keep a tight lip on their parts lists.
Nov 22, 2007 | Kenwood VR-309
IR Reliability--Intermittent
The Kenwood VR-510 does indeed respond to IR remotes. I now use a Logitech Harmony H659 which is IR only.
Your issue is a problem with the VR-510, actualy the whole series had a problem with cold solder joints on an assembly behind the front panel. Fix that and fix the problem. It frustrated me for 5 yrs.
Go here for the fix:
This site has the fix well documented:
All is working great now!
Jun 08, 2007 | Kenwood VR-510 Receiver
Remote control failure
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
Feb 06, 2007 | Kenwood VR-409 Receiver
Kenwood VR-505 Receiver Logo
1,735 people viewed this question
Top Kenwood Audio Players & Recorders Experts
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
