Question about Hotpoint Dryers
Putting the belt back on this dryer - Hotpoint Dryers
  • 97 Answers
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Posted on Jun 26, 2009
Belt come off! Need access
depending on the way the dryer is built you may need to take the dyer's top panel off then the front panel of the dryer to get to the internals while laying the dryer on its back to make it more easy to put the dryer back together when done if the belt however has snapped you can actually buy belts for the dryer you own er....one more thing make sure its unplugged before doing any of this but while its apart take your time to clean the dryer out with compressed air this will prolong the life of the dryer you own as well all dyers are easy to take apart and put back together as everything just snaps into place or screws back into place (PS: i worked on a LG TROMM dryer and it was easy as pie to put back together after cleaning and diagnosing it)
Feb 22, 2017 | Dryers
I HAVE A MAGTAG PPTS20 HOW DO I DO THE BELT
If you are talking about replacing the belt wit a new one.
YOU NEED TO FIRST UNPLUG THE DRYER!
This is a difficult procedure, you have to take the dryer apart, this includes removing the drum. after you remove the drum, place the belt around the drum, there will be a place worn where the old belt was, with the belt on the drum put back in the dryer, place the belt on the motor pulley with the tension pulley pushing on the belt. Make sure to get the felt around the drum in the back. Replace the parts you removed. plug back in and see if runs ok.
This is very difficult and is why we get $95 + parts
Thank You
Jerry
Aug 31, 2014 | Maytag Dryers
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Jan 04, 2009 | GE DBXR463EBWW Electric Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer belt routing
the best way i can tell you is open the back put the belt on the motor then visually pull the tension pulley back and put the belt on the tension back on the belt. if you are changing the belt you must touch the spring.let me know how it goes.
Nov 11, 2008 | Dryers
Hotpoint condenser dryer ctd00
change the drive belt. evidently the belt has stretched to the point the belt tensioning device can no longer do its job. when you change the belt make a diagram of which way the belt is reaved through the tensioning device. if you don't you'll be back here asking how to arrange the belt.
Jun 19, 2008 | Hotpoint TDC32 Electric Dryer
Tumble dryer
pull the front off then put the belt around the drum then pull the idler pulley back to put tension on it and put the belt around the motor pulley let the idler pulley back against the belt to keep it tight replace the front and your done
Mar 12, 2008 | Dryers
Dryers Logo
174 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
