Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Freezer compartment ice build-up
Kenmore Elite Model #795.75546401 bottom freezer compartment developing an ice build up. In addition, frost appearing on back of the freezer tray/compartment. How do I defrost? Is this a bigger issue than just defrosting? Thanks!
  • 245 Answers
Too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Posted on Jun 26, 2009
My Kenmore Model No 596.69282012 bottom freezer fridge develops a thin sheet of ice on the bottom of the freezer compartment. I have checked the freezer seal and it is intact. Any suggestions?
Is it supposed to be a frost free freezer?
I had one to act like that, but it was on warranty and they repaired it for me.
I wish I could have been able to help.
May 15, 2017 | Kenmore Refrigerators
Frost is building up in freezer compartment
  • Sounds like you have a defrost problem, either a bad defrost heater or thermostat
Aug 26, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I have a Kenmore bottom fridge model #596.69274991. Although things are cold and frozen, the room temp is only 70 degree but it seem to run for well over an hour although there has not been much opening...
Tom, you pretty much have it all covered. Make sure both the freezer fan and the fan under the fridge are both running and keep your eye on the inside back wall of the freezer compartment fro any signs of frost build up (possible defrost problem).
Jun 12, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator was making a 'Thump'' noise every so often and just stopped working. Freezer is still working It's a kenmore elite 3 door bottom freezer refrigerator model number 76539
Unplugging for an hour won't allow it to defrost if that is what the problem is.
Look inside the freezer at the back wall. Look for heavy accumulations of ice building on the cooling coil, which is behind the back wall panel. You may have to look in the louvers or past where the evap fan is located.
Once we know if there is heavy frost or ice there, we'll have a better idea how to resolve. Is there any warranty on this refrigerator that you know of, besides the 5 year compressor warranty?
Dec 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
Mar 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice build-up in freezer - Kenmore Model C978-66795-2
don't know this appliance but for guidence:
some appliances have the evaporator in a compartment at the top of the freezer and the drain comes out of the back and runs externally to the drip tray. there should be a grill in the compartment so just peer into it and see if there is ice build up.
wherabouts is the freezer ice forming?
Sep 04, 2008 | Refrigerators
Fridge freezing
a defrost problem, is gonna cause excessive ice build up in hte frezzer lower compartment. for somereaon the hdefrost heater was not energized. most common reason is a bad defrost thermostat, clipped on one of hte evaporator coils has gone bad,
Mar 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
834 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
