Question about Peg Perego John Deere Gator HPX Ride on Toy
Replacing Battery It it easy or feasible to replace the battery with a tractor battery that would last longer?
  • 850 Answers
I would go with a sealed marine battery!
Posted on Jul 24, 2009
    Habit-Forming:
  • 156 Answers
You should be getting around 3 to 5 years from these Peg Perego Batteries.
I have some that have lasted up to 6 years, but most of them last about 4 years.
Hope This Helps
Posted on Jul 17, 2009
Received a watch last Christmas. Have replaced the battery several in this past year???? Last time I replaced....watched & stopped running in last than 2 weeks??
Two things spring to mind.
Most likely is that it needs a lithium battery which are more powerful and have a longer life. Someone is replacing is with a standard silver oxide battery.
It is has a leakage drain fault and needs to go back under warranty.
Dec 05, 2017 | The Watches
B&d FHV 1200
The older batteries in small appliances only last a few years and then they need replacing. This will get worse until it fails completely.
It's time to replace the battery or the whole vacuum.
The newer appliances use lithium batteries, which will last longer.
Jun 16, 2017 | Cars & Trucks
What size battery for masport 155/1056
The largest battery that fits the battery holder
i fitted a lager battery than the original factory as they last longer than the original more starting power
I cut the battery holder under the seat so to fit larger batt
Feb 11, 2015 | Garden
The ups does not want to turn on
The most common problem with UPS that no longer works is that the battery is dead. They often do not last longer than a few years. Replacement batteries can be bought rather inexpensively at any battery store. Usually they are some combination of 12 volt 7 amp sealed lead acid batteries. Replacing them usually get the UPS going again.
By the way. If you do not want to go to the expense of replacing the batteries, the UPS usually still functions as a first class surge arrestor and line filter.
Nov 11, 2013 | APC Symmetra LX UPS System
50 timecutter with 21 kohler courage key wont start must short across starter to start
If you jump the starter from battery and it starts, this is what I would do. Use a multimeter and ground black lead from meter to neg post on battery. Take red lead from meter and touch to battery side of solenoid. You should have 12 or more volts. If so, touch red lead from meter to small terminal on solenoid and turn key, you should have 12 or more volts. Last, touch red lead from meter to the other side of solenoid and turn key, You should have 12 or more volts. If first two leads pass the test but the last step fails, you have a bad solenoid. They are usually fairly cheap and easy to replace. Just make sure to disconnect battery before replacing solenoid. If all these pass the test I would replace the keyswitch. I hope this helps you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 30, 2013 | Toro Garden
Battery not charging
Looks like the battery is wasted. I'd have it replace it. A new battery should keep charged for longer period of time.
Jun 19, 2012 | John Deere Garden
I have a 2006 Toyota Highlander Limited with original Panasonic Battery. Purchased vehicle new in Dec. 2005. Know the battery can't last much longer and need to know what is best replacement battery for...
My 2004 v6 2wd highlander has the same battery, and I am just now replacing it. What is that 7 years? I found via google that it has 550 CCA. I think it would have lasted longer if not for kids leaving lights on every few weeks and an unusually cold winter for this far south.
Dec 12, 2010 | 2006 Toyota Highlander
Nikon Cool Pix 7900 Battery door won't stay closes
There are plastic clips on the battery door and body of the camera that lock the door in place. If they are broken of the battery door the door can be changed. If the clips on the body are broken the camera as a rule is history. Replacing a camera body is not a feasible repair.
Jul 02, 2009 | Cameras
Computer is not holding the charge of the battery
Most likely it is the laptop battery, The PC will suddenly lose charge, the battery needs replacing, in my experience laptop batterts last about year before they get to 50% to 10% holding charge otherwords need replacing.
Jun 13, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Peg Perego John Deere Gator HPX Ride on Toy Logo
379 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
