Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Fuellines are gone need schematic to route lines
Fuelline diagram
Hi Rodney:
An interesting situation as having to replace all fuel lines is somewhat unusual.
If you google the model number along with "Parts Diagram" you may get lucky. Between the diagram and the saw you should be back to work in no time.
Jul 28, 2015 | Poulan Garden
Need schematic for fuel system 1989 fleetwood bounder
Schematic?
WELL, if it is a gasoline engine (you did not specify), there isn't much to the "fuel system..." only a single line with one or two pumps routing fuel to the fuel pressure regulator, and a single fuel line from the fuel pressure regulator routing bypass fuel back to the tank. Oh... and the fuel rail and injectors, which are all connected to the fuel pressure regulator.
If it is a diesel engine, it is even simpler!
Why would you need a diagram??
May 21, 2015 | Cars & Trucks
Fix fuelline
fuel lines MUST be repaired properly!!! where is it leaking at matters as to how you fix it
Apr 22, 2014 | Pontiac G5 Cars & Trucks
Vaccuum hose routing diagram 4.3 liter engine 1995chevy blazer
should be under your hood on the edge where the radiator is there is a few diagrams there timing settings vacume hoses etc if they are gone just use your search engine on images intesd of web it will pop right up
Feb 02, 2013 | 1996 Chevrolet Blazer
1982 Honda CB750C vacuum line routing
Hi, Rchrdsnsctt for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1982 Honda CB750C vacuum line routing Google Search
1981 750 honda vacuum hose routing
Honda CB750F2 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB750F2 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 19, 2011 | 1992 Honda CB 750 Nighthawk
Im getting gas smell in my car
common subaru problem relating to a leaking fuel line fitting on top of the engine under the hood. you are going to need someone with some mechanical prowess to fix it. take a gander at this website, has pictures http://****.com/fuelline/fuelline.html
Jul 06, 2011 | 2001 Subaru Forester
What would make the fuellines hot when trying to start this truck? also still wont start.
It sounds like this a dangerous situation. The engine may be using the fuellines as a ground. This would be like putting an electric spark next to gasoline. You may have another wire laying on the gas line somewhere. Check your Ground wire to the block.
The obvious thing to blame is the fuelpump, but there is both a fuse and a Relay to blow out. If these are not blown, the power that is heating the fuelline is coming from something else. The Fuelpump fuse and Fuelpump Relay only protect the Positive wires and there is nothing to protect the Negative wires. The Fuellines would be Negative ground and Unprotected.
Since your truck is not running, I would try a tool to check the Starter draw while cranking. Since Electric flows to the path of least Resistance, the Starter may have more resistance than the fuellines. You may have to take the Starter into Autozone or Oreillys for tests. You may have a short in the Alternator throwing a Positive charge to the Chassis
There is no telling what may have been Zapped if the Chassis got a Positive charge. Listen to the Fuelpump to energize before you use the Starter. There is an Inertia sensor which has a Pushbutton to Reset, probably under a Kickpanel.
Would like to know the outcome of this.
Jul 19, 2010 | 1992 Ford Ranger
Owner manual has gone awol. Need a schematic. I
I don't know what engine you have but the 3.0 liter is the most common.
Below is a diagram for the engine. If it is other than the this engine you can get additional diagrams at www.autozone.com.
Good luck.
Regards,
Sep 08, 2009 | 2000 Plymouth Voyager
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
80 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
