Question about Whirlpool Refrigerators
Ice maker makes hollow ice cubs or cubes with
Ice maker makes hollow ice cubes or cubes with water still in them
    Problem Solver:
  • 16 Answers
Whats happening is the ice isnt freezing all the way. Try cleaning your condensor's under the frig.In Hotter weather when condensor's get filled with dust it causes the frig to cycle to ofeten. In turn your cubes aren't freezing all the way.
Posted on Jun 27, 2009
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
Hollow ice cubes. Ocassional clunk sound and
Hollow cubes indicate the water inlet valve is defective ( not letting enough water into the ice maker ) . Replace the valve behind the refrig ( the piece the wall water lne connects to on the refrig ) . Do not try adjusting the water on the ice maker itself , even if someone else suggests it , as this adjustment is factory preset .
Sep 25, 2009 | Amana Refrigerators
Making hollow ice cubes
Hollow ice is a sign of not enough water going into tray . Replace the water inlet valve (piece that the wall water line connects to on refrig ) .
Aug 29, 2009 | Refrigerators
Maytag msd2356ae ice maker will only give me hollow ice any ideas.
Hollow ice cubes are most often cause by insufficient water supply. Icemakers fill for about 7.5 seconds, resulting in about 4.75 oz. (140 cc) of water into the ice cube mold. If there s not enough water pressure available at the fridge, cubes may end up hollow and/or the fill could continue to dribble, eventually causing the fill tube to freeze closed.
pls rate my suggestion.........
Jul 25, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice cubes are hollow.
some fridges are designed to make hollow cubes where they always hollow or just recently
Apr 13, 2009 | Refrigerators
550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Jul 12, 2008 | Sub-Zero Bottom Freezer Refrigerator
Fridgeidare freezer
how old is it ??? it only makes 8 ice cubes every 2.5 hrs or so when running correctly.some times 5 cubes depending on model. try reaching into the ice maker and feel the ice being made is the tray full or is there empty slots in the ice mold(asif not enough water). are the cubes hollow??( a sign of low water pressure)). have you replaed the waterfilterrecently (if applicable) old filterwill restrict water flow.
Mar 16, 2008 | Refrigerators
Ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Mar 05, 2008 | Refrigerators
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
514 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
